Question about Xerox WorkCentre 220 All-In-One Laser Printer
Xerox Workcentre PE220 Rubber belt is torn
The rubber belt that helps to feed paper is torn. Is there a way to replace only this part? And if yes, where to find the part number and the instructions on how to replace it?
Thank you very much.
Sincerely,
Raisa
3 Suggested Answers
SOURCE: Xerox Workcentre PE220 doesn't load paper.
No need replacement. Take a sandpaper and clean the roller. Well, all done.
Posted on Oct 04, 2009
  • 78 Answers
you need to follow on your edocs.find a part number for your pick up rollers.
Posted on Dec 11, 2009
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
No paper feed
Pull out a paper cassette and you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Jan 13, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Paper jams just as it comes out of the tray. It's
hi.have a look at your tray feed clutch.strip and cln
Nov 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Workcentre PE220 doesn't load paper. Stopped loading paper, and I found a torn rubber ring inside. I found where it was, but can't figure how to replace it.
It sounds like you need to replace your paper pick roller. It is held on the shaft by some white plastic clips. You can pry the tabs up and slide them to the side, then rotate and drop out the pick roller assembly. You'll need to find a source for that part.
Jul 06, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Xerox WorkCentre 220 All-In-One Laser Printer Logo
130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
