Question about Philips GoGear HDD6330 MP3 Player
My Phillips GoGear 30GB wont turn on
It has a full battery, i only just charged it and it wont turn on. I tried plugging it into the charger which usually automatically witches it on but that didn't work either. Also my computer wont recognise it. It was working just yesterday!!! Please can anyone help me?!?!?!
  • 3 more comments
  • Anonymous Nov 02, 2007
    mines done the same
  • yunguna Dec 01, 2007
    I fully charged my philips gogear yesturday and used it for 1 hour when i tried to turn it back on the next day the battery was dead????? y
  • Anonymous May 01, 2008
  • ashleighrabb Jun 05, 2008
    My phillips gogear won't turn on, can anyone help me please? if you ohold odnw the button it says "Go Gear" Then goes toa lit up blank screen....
  • sellyxxx Aug 31, 2008
    my mp3 30gb wont turn on it is fully charged and i left it for 6 days then it started working then after 5mins crashed now it wont turn on at all. when i plug it in to the computer it does not recorgnise that it has been plugged in i need some help on what to do???
Mine did the same thing today after me buying it yesterday. i found that when I hit the RESET button, and then pressed down the power button, it worked again.
Posted on Jun 26, 2008
It happened to me too
Posted on Jun 08, 2008
Omg mine did the same thing. such a rip off :(
Posted on Jan 30, 2008
It wont stay on
Is it turning off with charger connected or without charger?
If it is turning off while charging also, Try doing a soft reset.
  1. Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
  2. Hold until the player shuts down.
  3. Power on the player again by using the Power on/off key.
If this doesn't help, try repair it using Philips device manager program which came with the CD or downloadable from Philips web.
Apr 19, 2014 | Philips GOGEAR SA6045 MP3 Player
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
Will not turn on. this mp3 player has been on the charger all day
it may happen that the battery itself is brocken!!because it is over charged you said that its been charged all day...that might be the problem because if its over charged then theres a possibility that it wont be turned on or wont work..try changing the battery and try to turn it on..
May 18, 2009 | Haier ibiza Rhapsody Digital Media Player
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Apr 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Phillips go gear 8gb
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GoGear SA5285/37 Digital Media...
Gogear
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Feb 21, 2008 | Philips GoGear HDD075/17 MP3 Player
Charging
Double-check the software version of the new one and compare with the version on Philips website at www.usasupport.philips.com
Jan 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
910 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
