Question about GE Refrigerators
I can't find the water filter on this refrigerator: GSS22 JETA WW. Does it have one? If so, where is it, and, what is its model number?
  • 1073 Answers
SOURCE: will not make ice but
check the dual water valve one side is for the icemaker the other for the water in the door
either a water valve issue or a ice maker problem
if the valve checks good check the line off of the valve to the ice maker you should be able to blow thorugh the line to the ice maker if you caint blow through the line it is frozen in the freezer behind the icemaker and will need to be thawed
if you can blow though the line to the icemaker
replace the icemaker
Posted on May 09, 2008
FreshWaterSy
  • 13 Answers
SOURCE: What is the part number for the water filter for a
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
Posted on May 19, 2009
  • 286 Answers
SOURCE: Do all ice maker refrigerators have filters on the water line
Most refrigerators dont have one, Usually you can install on in the supply line. If there was on it might be behind the frig
Posted on Jun 11, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
milten1
  • 1304 Answers
SOURCE: How do I change the water filter in the Whirlpool
the water filter is in the toe kick on the bottom
it is a push twist type and should almost pop out when in the right position.
the best buty online right now i know of is at appliancepartspro.com
your looking for part number AP3182816
29.00
tell them you want the dealer discount and order 3
you will use em and you might get an additional
15 percent off no guarentee
have a great day
Posted on Oct 06, 2009
Gss22 jeta bb
are you sure it isnt just the over fill catch basin in the back that leaked ?
Dec 08, 2013 | GE Refrigerators
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
