Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Problem for Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode...
Display on my Jenn-Air electric wall oven is very dim
By douglas9101 on May 11, 2009
I have a Jenn-Air 27" electric combination wall oven (microwave on top & conventional oven below). The LED display on the conventional electric oven has become very dim. The oven seems to work just fine with the exception of the display. Is this a common issue and do you have a suggested fix for this problem
Same Problem
May 24, 2009
-   Oven works fine. The only problem is a very dim led display.-   Guest
Best Solution
posted on Jun 15, 2009
Helpful)
moose449
Rank: Apprentice
Rating: 92%, 3 votes
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 20, 2009
Not Rated)
kevinkim1
Rank: Apprentice
Rating: 0%, 0 votes
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 27 in. Electric
Questions and Unsolved Problems for Jenn-Air 27 in. Electric
Do you recommend Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection?
Answer
Answer
I have an old wall mount convection oven. The model number is illegible. It has knobs for mode and... (More)
Answer
Hello, I have Jenn-Air W131W electric ovens. They look like a double oven, but I think they are 2... (More)
Answer
My jenn air wall oven (about 12-15 years old) fan keeps going on and off. It usually runs the time... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
in , PA
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
