Question about Canon PIXMA MP170 All-In-One InkJet Printer
Ink cartridge hi i recently changed the cartridge in the mp170 canon printer, and it says it can't print because it cannot detect the ink levels, can someone help?
  • Seldom Nov 05, 2007
    I have installed a cartrige that was refilled by a company, and the printer will not accept it. Canon MP 170
How do I clean the heads so my printer will print
Posted on Nov 08, 2007
  • 425 Answers
Hi
try cleaning the terminals of your printer cartridge and your new ink and install it again...
if samething happens try installing again your printer.
if still nothing happens maybe you purchase a deffective ink cartridge...
if that happens you can return it to the shop were you bought it and demand for a replacement cause most of manufacterer have warranties for their products...
hope it helps...
Posted on Oct 13, 2007
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Check ink U051
Did you recently change the cartridge?? Make sure it is connected and fit properly.
If the problem persists, try to just disable the ink monitor. You will have to take care of the ink levels yourself. :)
Press your Menu button repeatedly until "Maintenance" appears. Use your arrow buttons to select "cleaning" and press "OK". Run a test print in between cleanings so you can see if you're making any progress.
May 21, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Or
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer
You can download and install the Canon printer drivers from the
Canon WEB site. Please click on this link and select your model printer :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jul 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP150
Besides service tool, mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Reset Ink Counter.
Reset ink counter that is resetting ink level (ink metrer) cartridge at printer.
  • Reset Black – reset level black ink cartridge.
  • Reset Color – reset level colour ink cartridge.
  • Reset Main (main).
  • Reset Platen (additional).
go to this website download this software after that install it follow by instruction that i give to you do reset....
http://www.mediafire.com/file/yan3ytvdumt/MPTool.zip
Sep 16, 2009 | Canon PIXMA iP1600 Printer
My printer is canon IP 1900 Series. my canon problem is error messege display ''the following ink may run out.balck.. the function for detecting the remaining ink level will be disabled since the ink level...
It would appear that the black ink cartridge is either out of ink or running out soon.Change the cartridge.If your need to print now and don't have a new cartridge try this open the unit pull out the black cartridge shake it and the reinstall it you may get a little more out of it.If this is a new printer the cartridges install are always limited in use,so you'll buy more.If you must print know try changing your font color to dark blue avoiding black.Good luck.
Sep 05, 2009 | Office Equipment & Supplies
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP170 wiont print with non-canon cardridge
yes you should
Most of the canon printers works only with canon cartredges and the canon company ends the warranty agreement when discovering that.
my advice: use the better quality and the Original ink (Canon Cartredges).
Apr 07, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
221 people viewed this question
old marine
old marine
