Hello how are you, would you happen to know how could I change my CMOS battery in my compaq aramda 1130 T laptop.
Thanks.
Thanks, but I already have the New CMOS Battery I just want to find out how to replace the old one an put in the new one?
Thank you
Hello thanks,
This Information was already found on googles searh engine
(http://www.tertullian.org/rpearse/armada/index.htmarch) I already have the laptop opened and followed steps as well as identifying the Cmos Battery I just need the step by step instructions to get it removed and replace with a New one.
However the link above only shows what to do when you break the CMOS's battery Support hinges/barrier, I need the steps to remove it for my Cmos Battery support hinges/barrier is not broken.
Thank You
grab the batt out and look on it for the serial and product number on it. use a local it service man to order in a new battery, as their are many "dodgy" ones floating around on the net!
good luck!
(any it repair shop/man wil help you out)
The CMOS battery is a small silver cell battery held in a grey plastic
clip at the top left of the case. The part number is 117099/001. This is identical to the
one for the Compaq Aero, which leads one to wonder just how old some of these batteries
are.
The new battery should not be handled. I used a piece of paper to hold it. The problem with changing these, is that the spring-clip that holds them in seems to be fragile. The battery would seem to be intended to be removed horizontally, with two arms of the plastic holder springing out. In fact mine had become brittle and just snapped. I know of another user who had exactly the same problem.
So, how did I fit my battery? There are two pins underneath, which push the battery up, and a metal clip which pushes it horizontally. The battery needs to be snug against both of these, or it will not function. The battery should be mounted with the side with the (+) on upwards.
I bought some electric insulating tape from Tandy.
I placed the battery in the holder, and stuck it down to the motherboard with a small piece of tape. This took care of the upward push.
Then I got a bin-tie. These come with rolls of plastic bags, and consist of a metal strip encased in plastic, which can be bent and twisted to close bags. I took one, made a loop the size of the holder, and twisted it shut. Then I looped it around the battery and pulled it into the horizontal clip. This took care of the sideways push. The battery was never going to untwist the tie, after all!
Finally I taped over the whole arrangement, to ensure that the tie could not fall off while the laptop was being moved.
I then applied mains power (don't use the laptop battery while doing config stuff, in case it fails part way through), and it all worked!
enuff info?
