Question about Adobe Photoshop 7.0 for PC
Code forascent tv
I just purchased a new tv from a large canadian store  (ZELLERS)small24 inch tube type. I got a very good deal as they had lost the remote, I cannot find thismake listed anywhere.   Could this be manufactured by any other maker or is there any other way around this problemhope you can help .
  • bottles Oct 13, 2007
    have spent hours with many remotes attempting exactly as you suggest -all without success.  but many thanks for trying BOTTLES
  • 425 Answers
Hi maam
so your trying to find a remote control for that tv?
try purchasing a universal remote control and just do trial and error method in setting the correct compatible frequency found at the manual in your universal remote since you cant identify the manufacturer of the TV.
hope it can help you..
Posted on Oct 13, 2007
Need codes as well as instructions to program Sanyo tv and direct tv reciever
It might be easier to just go out and purchase a Universal remote control at your large drug store or electronics store. They include instructions for getting the codes from each device you need controlled and storing those codes.
Jan 20, 2013 | Televison & Video
I have a Gio 500w ebike. The tube inside the back tire needs to be replaced and I cannot find the size to buy anywhere.The Gio website sells them but dont give u the size. I was also told that you can...
Hi! I have 2 Gio Scooters. I looked and looked for a tube for my tire and couldn't find a place until I realized that if you go to Ebay online you can actually buy them through Sven the supplier who sells the Gio Scooters on Ebay. You can just buy them from him and pay through paypal. Make sure the valve is curved and not straight out or it's not the right one. He ships pretty fast too:) I hope this has helped. It took me awhile to get parts. He also will ship parts, he's out of Vancouver. So Good Luck:) Do you know anything about fuses for these bikes???? Grrrr....
Jun 15, 2011 | Health & Beauty
Lost connector from dvd player to tv
you can purchase the connector from any electronic service store around you.
or from any store that deals in the parts of electronics.
ebay could be of help.
take care
Jun 03, 2010 | Cyberhome CH-DVD 300 DVD Player
Broken coffee carafe
Was expressing my opinion. I will buy a different model when I find one Thanks
Jul 31, 2009 | GE 106591 Coffee Maker
Difference in waterline hookup between old and new icemakers
this is so often the case with some of the larger companeys. there are only two types of connections for these water lines. 1st is a compression fitting 1/4 inch 2nd is a push lock style also 1/4 inch. Both styles can be purchased at any large hardware store. they should be with pipe supplies. Hope this helps and good luck.
May 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
RCA CTC203 chassis-Flyback and hot replacement
Use the one that comes with the new transformer. The old one can be removed by squeezing the sides of sucktion cup.
Dec 15, 2008 | RCA F32668 32" TV
Should be able ti fix it if you can solder and do basic troubleshooting. If you would like to get the service manual let me know and i will post a link.
Mar 05, 2008 | Philips 60P8341 60" Rear Projection...
My Mitsubishi WS 55511 died.
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Mar 03, 2008 | Mitsubishi WS-55807 TV
Picture tube doesn't seem to stay in place (standard tv)
A very good chance this tv was dropped or bumped. Sounds like the internal plastic frame is broken and will not support the picture tube. Find someone with tv experience to fix this. I would suggest they use a putty found at an auto parts store. To glue the tube and the frame together. This putty is in a plastic tube. You tear off a piece and fold it several times to activate. It will surely do the job.
May 30, 2007 | Durabrand DWT2405 24" TV
Adobe Photoshop 7.0 for PC Logo
153 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
