Question about Sony STR-DE845 Receiver
Can't get it out of Demo mode
Bought this used, with no remote, people were using a harmony universal. Had a demo prior to buying, worked great. Got home & hooked it up. When I plugged it in it powered up just fine, went into it demo mode, message said push the power button while this message is displayed to exit demo. Pushed it, nothing still in demo, no buttons work. I have checked and rechecked all connections, there is nothing hooked up wrong, no crossed wires or grounds. HELP ME PLEASE!!!!
  • 425 Answers
Hi sir,
if all the buttons dont work when pressing it, maybe there is a lost connection of the buttons or buttons are shorted. try to check it out...
hope it can help...
Posted on Oct 13, 2007
My tv screen is displaying buy this tv,how do I get it to work again.I don't have remote
Hi Melissa, sounds like it is a display model that is in some kind of demo mode! You will need to access the settings page, this will probably require a remote unless you have buttons on the unit....you could try using a universal remote!
Oct 26, 2014 | Televison & Video
Tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
on Aug 01, 2010 | Philips Magnavox 27MS343S 27" TV
Turn off demo mode on Pioneer vsx 322 receiver...how..?
Press the "home" button on the remote, down left for the arrows.
Then go trough the menu with arrow up/down, until you find "FL DEMO", then press OK, and switch to DEMO OFF :)
Sep 16, 2012 | Pioneer Audio Players & Recorders
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
Jul 08, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Can't control DVD functions from remote
absolutely ridiculous. i ran into this problem too.
Mar 01, 2008 | RCA L26WD26D 26 in. LCD TV
Rolling menu on screen
sounds like you have it in demo mode. In the menu will have it labeled demo on or off
Dec 09, 2007 | Zenith B32A24Z 32" TV
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Sony STR-DE845 Receiver Logo
341 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
