Question about LG enV VX9900 Cellular Phone
I dropped my phone in water. i put it on the charger and now everything works but the screen. will a new screen help
  • Anonymous May 14, 2009
    I DROPPED MY PHONE IN WATER AND EVRYTHING HAS WORK FOR A FEW DAYS EXCEPT NOW THE FRONT SCREEN IS WHITE WHEN EVER ITS ON
Stop turning it on or it will completely *******.....
open up the phone and place it in a hot press for 2 days....
Posted on May 11, 2009
Fix screen
Try taking back off and battery out and put everything in a bag of rice for a couple days and see if that helps. It worked for me when I dropped my phone in a bucket of water
Jul 21, 2013 | Alcatel Cell Phones
Coffee got on phone.I took battery out right away,put everything in rice.After 24 hours put battery back in .no picture or anything on screen,but i was able to make calls,i then put the phone on charger...
when a phone is liquid damage especially salt water, coffee and soft drinks then very likely it will not work properly especially the screen as the liquid sips through the edges of the screen
May 24, 2011 | Cell Phones
I dropped my phone in a class of water on accident and I took it out everything works there's just spots on the screen and its hard to hear people talk. I put it in a big of rice is there anything else I...
Idk if this will work but try putting it infront of a hair dryer. DO NOT put it very close to the dryer, put it at a distance but not to far away. After words put it on the charger. Remember take everything out of the phone....INCLUDING THE SIM CARD if you have one.
Jul 02, 2010 | Cell Phones
LG Dare dropped in Pool
Just put it in a bag of rice for couple of weeks. The rice pulls all the water or wetness out of the phone. How do I know, Well I found a brand New Lg Dare phone in a puddle, put it in rice for 2 1/2 months. I took it out of the bag, put it together, turn it on. To my amazement it worked. Ran to store, bought a charger, and it has worked every day since.
Jun 18, 2009 | LG Dare VX9700 Cell Phone
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
My LG Vu says Emergency download after I dropped it in water. And it won't do anything but go to that screen fell into the toilet and when i tried turning it on i saays Emergency Download
Take out the battery....then put it back in. Do not try to turn on the phone yet. Next plug the phone up to charge. Wait until the charging screen appears and then power the phone. Worked for me.....good luck.
Dec 30, 2008 | LG Vu CU920 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Dropped in water
the water probably caused a short in the screen conector.
sorry but liquid and electronics just don't mix
Nov 07, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Screen wont work
If you have a dead screen: You must Disconnect the ribbon cable between main case and LCD screen. be carefull lifting the connector and put it back in place. To reach the ribbon cable, you have to disassembly the phone. Google search with 'Motorola V220 Full Housing Installation' for a detailed procedure with pictures. attention: It may void any waranty!!
Dec 30, 2006 | Motorola Mobility V220
LG enV VX9900 Cellular Phone Logo
145 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
