Question about GE WBSE2090A Top Load Washer
I have an older Whirlpool duet that reads sue code.It has water that has not drained fully with a odd sound towards the rear of machine possibly a short in board?
    Problem Solver:
  • 7 Answers
Is it SUE or SUD code?
Sud SUDS LOCK (Overdose of detergent detected during the wash cycle) The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Posted on Dec 06, 2013
SOURCE:
Duet washer does not drain all the way. clothes left in sitting water
sounds like pump not working fully.at the bottom fo machine theres a round plug.,that sounds blocked.open and unblock.alot of water will come out so get plent towels down.
Jun 04, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet wfw9250ww will not drain F9E1 code is displayed. How do I toubleshoot this?
F9E1 or F21
  • When users observe the F9E1 or F21 error code in their Whirlpool washer's display, it indicates a drain pump system error. The drain hose should be checked to ensure that it has been installed properly and not having a blockage.
Read more: Code List for Whirlpool Washers ' eHow.com http://www.ehow.com/list_7735284_code-list-whirlpool-washers.html#ixzz1wPUs4Ry6
May 31, 2012 | Washing Machines
I Have Probleme whit my Whirlpool (SUD F02) Thank you
It sounds like you have a Whirlpool Duet instead of a Whirlpool Cabrio as the codes indicate a draining problem. Press Pause/Cancel twice to clear the display then unplug the machine. Remove the screws attaching the bottom front panel then pull the panel down and off. Prop up the front bottom edge of the washer or cushion and lean it against the wall to access the screws more easily.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the drain filter by turning it counterclockwise and clean it.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Jul 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
There's an annoying beeping sound everytime i operate the whirlpool duet washer, but there is no code indicating what it is. i surely need help figuring this out.
Possible your filter is getting clogged or your water inlet is slow; possible i repeat. Check this out:
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there, it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. A nice rating if helped pl.........
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washing machine
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more "involved" error codes that has many possibilities for the cause. I would start with the simple things, first, in an attempt to rule out easy the possibilities. Check your fill hoses to ensure they are not kinked or clogged, followed by verifying your installation to ensure you don't have a siphoning problem, Then, check the drain pump for operation. Read through the link thoroughly andlet me know if you have questions. I hope this helps you.
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Wont Drain
Sounds like a relay on the board. Have you tried to reset the machine by switching it off at the wall and leaving it for about 20 seconds before switching on again?
Oct 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WBSE2090A Top Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
