Question about Weber Genesis E-310 Gas Grill
Grill not lighting - Weber Genesis E-310 Gas Grill
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the push button igniter next to the burner control knobs on the front of your grill.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the grill has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck
Posted on Jul 17, 2010
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
How to install a grill for a 2001 volkswagon beetle
TO REMOVE GRILLE FROM BEHIND THE BUMPER COVER RELEASE PLASTIC CLIPS AND DETACH THE GRILLE. IF YOU HAVE FOG LIGHTS DISCONNECT THE ELECTRICAL CONNECTORS FROM THE FOG LIGHTS AND REMOVE THE FOG LAMP MOUNTING SCREWS BEFORE DETACHING THE GRILLE.WHEN YOU INSTALL GRILLE PLACE GRILLE IN POSITION AND SEAT THE CLIPS INTO HOLES IN THE BUMPER COVER. IF YOU HAVE FOG LAMPS INSTALL GRILLE IN POSITION THE INSTALL FOG LAMPS MOUNTING SCREWS BACK IN PLACE TO HOLD GRILLE IN POSITION.
Sep 25, 2011 | Volkswagen New Beetle Cars & Trucks
Our grill will not light. When the knob is pressed in and turned to 'light' I can see a light inside, but it's like it's not catching and it won't light up. Each burner is doing this....
It sounds like your grill may have a glo plug type of ignition system if there is a light inside the grill instead of a spark to light each burner. If your grill is hard wired to the house elelctrical, it may be that a breaker is tripped and the power is not getting to the glo plug and the grill us using a battery back up to try and light the grill. The batterys do not last long, and when they get weak, the plug will glow, but not hot enough to light the grill. The other possibility is that you have a short, or some other problem, that is preventing enough voltage to reach the glo plug, the plug will glow, but not hot enough to light the grill.
Jul 03, 2011 | KitchenAid KBNU487TSS Gas All-in-One Grill...
Can't get a decent flame after lighting the grill.
Sounds like you need a trouble shooting checklist! Click on my username, scroll down my profile and click on my tips and tricks for trouble shooting gas grill lighting issues. Hope one of then helps.
May 17, 2010 | Thermos Stainless Steel Gas Grill
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Grill willnot light
there is a blockage in the line!!!
Jun 10, 2009 | Weber Genesis Silver A Grill
Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Grill, top oven and all lights not working after grill element blows
Brinkmann has a terrible customer service dept. You are better off with a new unit.
Jul 30, 2008 | Grilling
Not lighting.
grill doesnt stay light
Jul 01, 2008 | Fiesta Advantis 1000 Grill
Weber Genesis E-310 Gas Grill Logo
643 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
