Question about GE 29897GE1 Corded Phone
Program numbers I want to progam phone numbers so My down-syndrome brother can just press 1 number to get help.
  • SpencerR642 May 11, 2010
    Not knowing the make/model of the phone makes it difficult but most mid-level or better phones of the past several years have a speed dial function. Try going to the manufacturer's website and search the support page for your model of phone. You'll either be able to download a current user manual or find a page that explains it.
  • 192 Answers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
Posted on May 16, 2009
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do you progam freguencies into my scanner
To program a known frequency into your scanner:
- Power the scanner ON
- Press the E/PGM key
- Enter the number of the channel to be programmed
- Press HOLD
- Enter the frequency, including decimal point
- Press E/PGM to store the data in the scanner's memory
To continue programming, press the up or down arrow to advance to the next channel.
Press HOLD or SCAN to exit the programming mode.
More detailed programming instructions are in the factory operating manual which you can download and print, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 14, 2010 | Uniden BC340CRS Base Scanner
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Re-programming phone numbers? How di I re-enter the numbers?
Hello
Thank you for using
FixYa for your problem
Press Menu/Set, 2, 3, 1.
2 Press the One-Touch key where you
want to store a number.
3 Enter the phone or fax number (up to 20
digits).
Press Menu/Set.
4 Use the dial pad to enter the name (up
to 15 characters).
Press Menu/Set.
(You can use the chart on page B-11 to
help you enter letters.)
OR
Press Menu/Set to store the number
without a name.
5 Go to Step 2 to store another
One-Touch number.
OR
Press Stop/Exit.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 20, 2009 | Brother IntelliFax-2820 Laser Fax
How do you progam the 1 touch key? also delete a
Press the additional key button,scroll to no 3 faxsettings,press ok,scroll to no 5 pro touch key,press ok,Program the one touch keys from 1 to 12
Oct 06, 2009 | Canon ImageRUNNER 1670F Copier
How do i program speed dial phone numbers into my brother intellifax 4100
Per Intellifax 4100 manual:
Storing Speed Dial Numbers
Press Menu, 2, 3, 2.
2 Enter a three-digit (a two-digit for
FAX-4100) Speed Dial number, and
then press Set.
3 Enter a number (up to 20 digits), and
then press Set.
4 Enter a name (or leave it blank), and
then press Set.
5 Press Stop/Exit.
I hope this answers your question. Thanks for using Fixya and best of luck!
Greg
Jun 12, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother faxes 8360P and 8000P - how do I progamme the machine to dial a 9 before each number please ? as my machines are connected to extensions on the PABX. Thanks
As I'm aware you can not program a number before every number you use. However you can progam the one touch or speed dials you can enter the 9 before the numbers. On some systems thay may need 9 then a pause then the number.
Nov 14, 2008 | Brother Office Equipment & Supplies
Brother 4750e
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
  • Press Menu.
  • Press the up or down arrow key to select Fax.
  • Press OK.
  • Press the up or down arrow key to select Miscellaneous.
  • Press OK.
  • Press the up or down arrow key to select Compatibility.
  • Press the left or right arrow key to select Basic (for VoIP).
  • Press OK.
  • Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Jun 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Will not progam
1. Turn on the device to be controlled
2. Press that devices button on the URC e.g. TV
3. Press and hold SET until LED blinks twice - then release SET.
4. Put in the code number supplied. The LED should blink twice.
5. Aim the URC at the device to be controlled (e.g. TV) and press power button once. Device should turn off. If not, repeat entire procdure trying each code number supplied.
Remember that there is some help available at www.oneforall.com
Feb 13, 2008 | One For All URC4220 Remote Control
GE 29897GE1 Corded Phone Logo
143 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
