Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
It is in the 30s here at night and I've begun using my heat for the first time (just moved in this summer). I keep turning up the heat (it is currently maxed out at 90 degrees), but there thermostat temperature won't climb higher than 73 degrees. I've had to bring in a small heater to stay warm in here. Any suggestions?
  • 89 Answers
Is there HOLD button?
Posted on Dec 06, 2013
3 Suggested Answers
SOURCE:
heatman101
  • 43501 Answers
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 12, 2009
  • 472 Answers
SOURCE: my robertshaw thermostat works well
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Posted on Jan 08, 2011
What causes pixels to go bad. i have 2 white dots on the screen. does it have anything to do with overheating..my dad leaves it on all day and most of the night.
The quality of the parts, engineering design in the electronic circuits and heat. Also the amount and size of the vent holes in the TV cabinet, which let heat escape. If the TV has adequate vent holes for heat to escape, leaving the TV on for a longer time should not increase the inside temperature at all. There really is not much you can do, except keep the room temperature cooler in the summer with air conditioning. Buying a cheap TV which uses cheaper parts can also affect quality of parts used in the TV.
Nov 01, 2015 | Televison & Video
I have a 2005 dodge durango that's over heating.
The basic answer is not enough coolant flow or not enough air flow thru the radiator. You'll have to find out if the coolant is flowing when the thermostat is open, is the system full of fluid, and is there enough air flow thru the radiator.
Does it get over 220 degrees if you are moving and at idle too ?
Jun 17, 2013 | Cars & Trucks
Vw lt46 minibus very cold start
Get a block heater installed in it, End plug it in over night, That will slove you problem,
Nov 11, 2012 | Cars & Trucks
Goodman furnace fan cylcing
The fan switch is set to turn on at approximately 125 degrees and run until the heat exchanger temp drops to around 105 degrees. With age the sensitivity of this switch varies and summer heat can cause the switch to turn on if the outside temp is over 100 degrees. Only the fan is running, not the burner but you can shut off the power to the unit if this is an issue.
Aug 27, 2012 | Heating & Cooling
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Jul 22, 2011 | Samsung AW1203B Air Conditioner
Heat pump and gas furnace running at the same time.
An explanation....
When in the heating mode, all heat pumps are dependent upon the outdoor conditions to remove heat energy from the environment and turn it into useful heat for your dwelling.
Heat pumps operate more effectively in temperate climates (as in southern states) and if it's as cold as you say, then the furnace is coming on to add auxiliary heat to the space to make up for the lack of heat being supplied by the heat pump. This is normal.
Some heat pump systems are or can be equipped with a control known as a "low ambient cut out" and/or "motor master" that prevents the heat pump compressor from operating and slows or stops the condensing unit fan when it's too cold and risking potential compressor damage. When it's in the single digits outside, a heat pump is only marginally effective. and usually requires auxiliary heat (your furnace).
If the furnace keeps operating when it's in the 30s or 40s, you may want to have the system examined by a competent service technician. As always, the outdoor condensing unit should be kept clean and the furnace filter should be changed no less than monthly, unless you have an electronic air filter.
Jan 07, 2010 | Heating & Cooling
98 voyage died entering highway rev to high gear 30s then just di
my suspect would be the alternator at this point. an alternator can cause sudden stall out while driving. did the lights(headlight/dash light) dim out when you stalled? do they dim when you try to start it. the belts and fan is intact? i dont think it will show a code if its not getting any juice from alternator. it also could be ignition switch but i need this info first.
let me know
Apr 07, 2009 | 1996 Plymouth Voyager
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
Heating & Cooling Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
