Question about Panasonic KXT 61610 R3 Key Service Unit Phone
What to dial to access panasonic esa phone 616
Dont have manual need to know what to punch on the phones to access the pa out put from the central unit
  • Panasonic Master
  • 2,460 Answers
Panasonic never issued a manual for R3. It was done with addendums that got you from R1 to R2 to R3. I think these are the right codes, but you may have to test them.
External page should be 33.
All Page (internal, I think) is 34. It's also the page transfer code.
Groups 1-4 are 35-38. (All phones are in group 1 by default)
43 is the "meet-me" code. It can retrieve any page or transfer to page.
Here's a link to a manual(s) if you need it.
http://public.carl.airpost.net/KXT%20Analog/KX-T61610_IM_PM
http://public.carl.airpost.net/KXT%20Analog/Panasonic%20KX-T616%20Station%20User%20Guide.pdf
Carl
Posted on May 11, 2009
Our office pabx is a Panasonic KX-TA616. I am trying to program personal speed dial on a Panasonic KX-T7730 (which has 12 CO buttons on the right but no Personal Feature buttons). Neither of the...
Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
In your country the other mate to that is the KXT-7667.
If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
How do i program the time for my pansonic esa phone
First you find the SET PROGRAM switch on the cabinet and put it into PROGRAM. Now, from a display phone connected to ext 11, you dial 00 and use the keypad, FWD button the AUTO ANSWER buttton and the STORE button to step through the various settings. The CONF button goes back.
Return the switch to SET when you're finished.
Carl
Nov 17, 2010 | Panasonic KXT 61610 R3 Key Service Unit...
Unable to dial 1800xxx or any other 1xxxx numbers
The things that control restriction (TRS) is class of service and Allow/Deny codes, or it may be in the dialing restrictions of the station.
Your system administrator or manual will have specific instructions on how to program the system as it's beyond the scope of a free and public forum to tell you how it's done. Once you understand it, it's a pretty simple program. In the U.S., we actually screen up to 10 digits, allowing 1800,1888,1877 etc. and denying everything else. We don't have the TA-616, but we do have the TA-624/824. Programming gives you about 20-25 allow and deny tables. If you do score a manual, check out TRS.
Carl
Jul 05, 2010 | Panasonic KX-TA308 Phone
Change from pulse to tone panasonic 616
If you truly have a 61610 circle 3, the Dialing Mode is programmed in system program 04. From a display phone plugged into ext 11, you put the system in PROGRAM mode via the switch on the system cabinet, then dial 04 and SP PHONE. You change from PULSE to TONE by pressing the AUTO ANS button and save the change with the STORE button. Keep pressing the SP PHONE buttone to step through the other CO's. Return the switch to SET when finished.
If 04 says something else, look at the silver tag on the KSU(bottom) and comment back with the model and if there are any circles with numbers on the tag.
Carl
Dec 27, 2009 | Panasonic KXT 61610 R3 Key Service Unit...
Seems to be locked into a program - do not have a manual
If using the KX-T7730 phone on a Panasonic 308/616/824 system press Program 11 and then AUTO DIAL / STORE . Press Program to exit programming mode.
If this answer was helpfull please vote
Thank you.
Oct 15, 2008 | Panasonic KX-T7730 Corded Phone
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
412 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
