I am trying to connect a dlink ANT24-0700 router booster to a Linksys wireless internet router. I realize I need to take off one of the antenna but do not know how to do that without breaking the existing antenna?
  • captavery May 11, 2009
    the Linksys router is a WRT150N router.
    related to problem below
    So far not much assistance.
    President:
  • 2,653 Answers
If you can't easily screw off the antenna then you'll need to take apart the router manually. What model is your Linksys?
Posted on May 11, 2009
  • RescueTechLA
    RescueTechLA May 11, 2009
    Here's an inside pic of the router.
    It looks like you'll have to do a little bit of work to get those antennas off.
    Router Picture
Home wireless internet
All routers are good routers however Linksys routers are really good routers and usually are a good price you can connect up to 8 wireless devices on most routers including your wireless phone. Also the range is usually around a 100 yards. however like I said most routers allow you to connect many wireless devices, but here is a list of good routers.
Linksys, Netgear, Dlink, Asus Hope this helped
Jul 15, 2013 | Computers & Internet
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
Will not connect to internet whether it is wired or not
connect the broadband modem to the internet port of your router (probably is blue). Then connect your pc to the router.
You have to set your router to act as dns.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Wireless signal from belkin n1 low even with dlink booster usb
try using wireless N routers .. gofor linksys Wireless ' N '..this gives u the best possible range other than wireless b/g..hope this helps...
Jul 08, 2009 | Computers & Internet
Linskys wireless-g broadband router not connecting to network
first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
Jun 07, 2009 | Linksys Wireless-G Broadband Router
WAP connecting to another WAP
On the D-Link WAN page, change IP Address to static and give it an address about 30 away from both the Hawking and the Linksys. On the DHCP page, disable DHCP.
In a multiple router network such as yours, you can only have ONE real router. The others have to be disabled as routers. Disable thier DHCP and give them static addresses that are all at leat 10? or more from each other. Wireless should all be the same setup. The on;y exception is the SSID which can be slightly different to know which wireless you are on.
May 31, 2009 | Hawking 802.11g Wireless-G Range Extender
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Replacing antenna on linksys wrt54g router
yes u can get a antena from retail store and get it and remove the old one and turn off the router and and connect the new one and turn on the router>rate me solved if its helps thx
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
