Question about LG Studioworks 563N 15" CRT Monitor
Crt screen power not appear
I have a problem with my crt 15" monitor in my monitor 1.power not appear 2.monitor colour not display correctly
3 how to adjust the colour there is no botton in the monitor control panel
1)check the power supply
2)write in a desktop<properties<settings
3)setting<control pannel<display,appearance
Posted on Mar 27, 2008
Yellowish screen
On a CRT, "yellow" is a mixture of all 3 "primary" colours.
So, if you are expecting some other colour, then one of the 3 "guns" that are emitting one of the primary colours is NOT working correctly.
For less than $100, you can purchase a new, 19-inch (not 17-inch) LCD (not CRT) monitor.
This is less expensive than taking the CRT to a TV/video store for trouble-shooting and repair.
Jan 07, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
I hve a sansung 48 v monitor. the screen is very much redish
CRTs use 3 "guns" to mix the 3 "primary" colours (RED, BLUE, GREEN). One of the other guns has stopped working, leaving the RED gun as the "dominant" colour.
Spend $30, and buy a pre-owned 15" LCD monitor.
Or, spend $100, and buy a new 17" LCD monitor.
May 26, 2010 | SAMTRON 55V 15" CRT Monitor
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
Monitor No display
1. Power is comming or not.
2.Check Horizontal Transistor.
3. Disply cable. 1,2,3, pins & 13, 14 pins continuty.
4. Filament supply , drypoints in neck board.
5. filament supply diode, capacitor.
Oct 23, 2008 | Samsung SyncMaster 551 15" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
My LG CRT monitor does not display any thing when powered on
My LG CRT monitor does not display any thing when its powerd on .
May 21, 2008 | LG Studioworks 563N 15" CRT Monitor
Color problem
1. if your monitor is old. due to aging it happens normally
2. Check monitor signal cable
3. Else the colour processing circuit is defective.
4. Check whether your monitor settings are set correct(default)
5. Contact monitor service centre for further rectification
Dec 22, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
143 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
