Have older Kenmore Front Load Washer Model#41741142000. Bought used and was not used for about 8 months. On first load, water leaks out of bolted seam at bottom of tub, mostly during spin cycle. Tried
Have older Kenmore Front Load Washer Model#41741142000. Bought used and was not used for about 8 months. On first load, water leaks out of bolted seam at bottom of tub, mostly during spin cycle. Tried tightening bolts but still leaking. Is there a recommended sealer, or is there a gasket to replace?
  • 1 more comment
  • traveler6017 May 12, 2009
    "Expert micromaster" evidently did not read my original problem post thoroughly. Of course, I already checked all fill and drain hoses and connections for leaks (none). The leaks are occurring around the bolts which hold the two halves of the agitator drum together.
    Thanks, GM Elec. I believe you have found the solution. However, I am not mechanic enough to tear the machine down and reassemble. Do you know of any "band-aid" type fixes? Like a sealant or caulk one might try? Otherwise, I'll have to live with it until it becomes unbearable and then take it to an appliance repair place, or replace the washer completely.
    Solution and follow-up by GM Elec was excellent, thanks. Will try suggestions and report back.
  • 1,000 Answers
Traveler,
There is a seal between the two drum halves. The part is available through the Kenmore web site. I believe it is less than $20. This is the 3rd one of these seals that I have heard of go bad, not sure why or what the problem is. Although the washers are some what older.
The web site is below. Also I will try to attach a diagram of your washer, the seal is item #21.
Good luck, let me know.
Regards,
www.searspartsdirect.com
Posted on May 12, 2009
  • Bruce Bracey
    Bruce Bracey May 12, 2009
    There is a compression sealant that is very good, but it would be best used between the two halves. You could try loosening the bolts to separate the drum a bit, then try to force some of the sealer into the joint and re-tighten the bolts.
    The sealant is Fernox LS-X sealant. It works with hot or cold water and seals under pressure. You can find that at www.fernox.com .
    Is there any possibility the water is leaking at the door seal and running back to the seam. That seems to be a common problem with front load washers. You might want to use some window cleaner and cloth the wipe down the front seal, make sure nothing is stuck behind the seal like one of those "ghost" socks, I've seen that happen before.
    Regards,
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
First check the hot/cold water connections at the faucet and at the back of the washer, make sure there are no leaks there. Also check the connection where the water drains out of the washer, it's the long U shaped hose attached to the bottom back and is inserted on the other end probably in a wall drain, make sure no leaks are there. You could turn the washer over on the front side but you would probably have to disconnect the hot/cold and drain hoses. simple more than likely to fix it a connection is simply loose.
If you purchased the washer new and not 1year older then you still have a warranty on the tub for leaks, check your warranty.
Let me know
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
41741142000 model noise insde tumbler sounds like a shoe ?
This will be one of 2 things, either the drum has separated from the rear mount (new drum needed) or your bearings are failing (new bearings needed)
Mar 05, 2012 | Kenmore 43042 Front Load Washer
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Leak at bottom bolt of drum seal
the entire tub must be removed - the most expensive of all repairs labor-wise.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer leaks
under the front panel ther should be techshet/ trouble shooting guide. and withthe front panelremoved perhaps you can see ewhere the leak is coming from
Mar 01, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 417.41042000 front load washer leak
Shell seal was replaced & problem solved, although it was a very labor intensive task
Jan 25, 2009 | Kenmore 43142 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
