Question about LG DLE7177 Dryer
No heat, stuck on "cooling"
My LG DLE 7177 RM electric dryer produces no heat and is stuck on "cooling" mode. Duct pipe was clogged so im suspecting it caused the problem. I cleared the clog but still no heat.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my dryer lg dle 7177 tumbles but does not heat
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 09, 2010
LG Tromm DLE 7177 WM not drying clothes. vent is clear and unobstructed, the heating element upper right is hot to the touch, and it seems there is a reasonable amount of air venting to the outside.
There is a upper limit and lower limit thermostat I believe, YouTube repair clinic channel has all the test info and parts.
https://www.youtube.com/user/RepairClinic
Apr 25, 2017 | LG Dryers
My LG Tromm DLE 5977W will tumble but won't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
Dryer functions but no heat; only cool air
unplug dryer and gain axcess to back of dryer and remove back wall plate look at lint shute bulkhead housing their will be one thermostat with four wires and one white plastic fuse safely remove the wires off fuse and tape together for testing only ...... make sure cover with electrical tape now make sure wires dont touch anything meatal no plug in dryer and check for heat if dryer starts heating goahead and order new fuse and replace thermal fuse ,,, and clean dryer venting and check for any kinks in vent pipe ........ if that test didnt produce any heat replace heating element its in aluminum duct on right side of the back of dryer ...... their is also a high limit tstat on the upper left side of this duct you can jump this out for testing only and check for heat aswell donot operate dryer with these jumped out except for testing theses are safety precautionary thermostats,,,
Jan 28, 2011 | Whirlpool LER4634J Electric Dryer
When I set the dryer to Heavy Duty and Very Dry setting which equates to 1:10 mins, my clothes are still very damp. This seems wrong. Thoughts?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 26, 2011 | LG DLE2532W Electric Dryer
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
I have LG dryer model DLE 7177 RM my dryer has power indicated by the drum light but nothing else has power except the drum light, what might cause this
Unplug it and wait a minute, then plug back in. This is my first line of defense, then all I know, is I won't buy another LG for my home. No one wants to work on them or they don't know how. I own 4 LGs in my home, 2 have had issues....grrrr.
Dec 21, 2010 | Dryers
My dryer lg dle 7177 tumbles but does not heat
heatman101
Apr 09, 2010 | LG DLE7177 Dryer
My dryer is not producing heat. Just cool air!
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 17, 2009 | Dryers
Kenmore Dryer Model 110.73952102
Yes, It is usually on the heating element tube. Don't just replace the fuse. You must find out what caused it to blow. You probablly have restricted air flow . Usually this is a clogged duct pipe or outside vent. This can also be caused by trying to operate the dryer with the door open. Before replacing the fuse, take the duct off the back of the dryer. Clean out what lint you can , turn on the dryer and see if you get good air flow. Next check the vent pipe for clogging and check the outside damper. DO NOT USE FLEXIBLE PLACTIC DUCT PIPE. It is a fire hazard and almost always clogs up fast. Another possible solution is that if it's an electric dryer, If the element burns out it can short out against the frame and cause it to overheat.
Jun 14, 2008 | Kenmore 73952 Gas Dryer
Fridgidaire FGRB5700DS0 Only Certain Modes Produce Heat
The control thermostat has failed. It's mounted to the plastic air duct that your lint trap slides into. You'll have to unplug the unit and remove the front panel to get to it. The part number is #131298400 and is available at a local appliance parts retailer. Cost is about $32.00.
Jul 29, 2007 | Frigidaire FGR341AC Electric Dryer
LG DLE7177 Dryer Logo
161 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
