Right cover will not close
Canon PC941 right cover will not close
    President:
  • 1,126 Answers
The lower right cover?
That cover is spring loaded. They are notorious for snapping the hooks that attatch to plastic frame.
It is possible to take a paperclip, straighten it out, heat one end and melt a hole to reattatch the springs at front and rear....it takes patience.
Posted on Jun 06, 2009
Hello I need exposure lamp for canon pc 941 how much and how many time my zip code is 00949 please send priority mail thanks santos
You have to find and order it for yourself. We just answer questions voluntarily, we don't provide service! These folks should be able to help you.
Canon PC941 Supplies and Parts All
Dec 07, 2016 | Canon Office Equipment & Supplies
CANON PC941 MANUAL
if you in front of the copier.
use the left hand to hold the handle. the position of handle is above of paper tray, fuse the handle and the scanner unit copier will be rise.
and you will see the meter reading/counter.
Feb 24, 2013 | Canon PC-941 Copier
Cant find how to change ink cartridge for canon pc941 copier
Have you tried resetting the copier by unplugging it and waiting a few moments? If you problems persist check us out online for all your copier repair or Copier Leasing needs.
Aug 17, 2012 | Canon PC-941 Copier
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
No copy from Canon PC941
P= Paper Empty or No Paper in Tray
Check Paper tray sensor.
If this was helpfull rate me.
Aug 01, 2010 | Canon Office Equipment & Supplies
I have an old Canon PC941. It has code E0 (which
yes its the fixing film you must replace it and you must do a reset of the error .
Apr 09, 2010 | Office Equipment & Supplies
Canon pc941 ink not drying on paper
It sounds most likely that the heat on the fusing unit is not working. This could be from a bulb blowing. My suggestion would be to replace the fusing unit as this model doesn't lend itself to fuser repairs.
Dec 31, 2009 | Canon PC-941 Copier
Pages coming out black and unreadable? PC941
check your upper high voltage charger, checkyour exposure lamp setting to bright,if persist change your tonner tank. thanks.
Oct 04, 2008 | Canon PC-920 Black and White Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Canon PC941
dear friend:you must check the following:-1is there a power in the wall outlet(try any equipment from the same source of power if it is ok try to chang power cord .2-if it is not working yet try to spray on power switch many times with contact cleaner{{from radio shack}}.3-open the front cover and close it firmly to confirm that door switch is working probably{better to do this as first thing}}
my best regards.
Feb 22, 2008 | Canon PC-940 Black and White Copier
65 people viewed this question
jasbo
jasbo
