I had the Daytec TV Plasma 42" on for several hours and it just died after making a grinding noise. I checked all conections and power sources. I am getting no light on the plasma tv. Other indicators are showing an active LCD light.
  • 1 more comment
  • howschm May 11, 2009
    Tried your solution but plasma TV still dead. The LCD ready light did not come on or respond as before. It was a good suggestion but it might be some other internal short. Do you have any other ideas.
    As before, I have a completely dead daytec plasma tv and the other devices (DVD player XBOX 360) have indicator lights and sork. No change with leaving it unpluged, I will try to leave it unplugged for a longer time but I am not likely to get a response. Could it be the power supply. Help please
  • howschm May 12, 2009
    problem was not solved but information about the problem was confirmed and therefore useful. Thanks
  • 15,935 Answers
If the TV is dead - no lights etc. the power supply board (or a component on the board) has failed.
Please don't attempt this repair - as there are potentially lethal energy stored inside, and they need to be properly discharged before repair.
Unfortunately - There is no easy end-user "quick fix". Having the power off for an extended time will have no effect on the unit.
Thanks for using FixYa!!
Posted on May 12, 2009
  • 749 Answers
Hi it seems like a burned out capacitor or resistor try a hard reset just unplug your tv from the cord for 30 mins and try it again.
Posted on May 11, 2009
HPT4254X/XAA clicking noises? Cuts itself off and continues to make clicking noises as if it is trying to turn itself on. I've had cheap tv's for 20 years and no problem. I'm not...
The tv power supply board it is the 90-95% the problems and the causes.That the board where the tv power a/c cord plug into it.Those capacitors components parts the tvs corporation put on tvs are under voltages for low heat resistance most of the times and dies very quickly, to dies as times used a lot of tv on like 3 or 4 hours a day within a year or litte bit more.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes?Take the the tv aparts and check the tv power supply board carefully for dying and leakages capacitors components parts.These dying and leaking capacitors parts are alway bulges up or puffing up on to it tops.All these dying and leaking capacitors parts that are bulges up or puffing up on to it tops.All these dying and leakages capacitors components parts must have be replaced like the same Micro Fared and those voltages on the new capacitor parts u are replacing should be in higher voltgaes like 5 or 10 voltages higher than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 25, 2011 | Samsung HP-R4262 42 in. Plasma Television
How do u fix a panasonic plasma tv when its not working as in unable to turn it on?
Tv have any power LED light indication at all?Or power LED light it is flashing?Check the outlet power source?Tries tv unplug,replug it back like an hour later for tv resetting back to the factory setting.Tv should be working again,if tv still have the same problems.The tv power supply board have problems and dying or dead.That the board where the power a/c cord plug into it.Take the tv aparts.Have tools and know basic electronic?Check the tv power supply board carefully for dying capactiors parts,like bulging up or puffing up onto it tops.These capacitors parts are dying and dead soon must all to be replace.Or try website like Ebay.com to buy a whole refurbish new power supply board for the replacement.
Jul 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Plasma hd tv takes hours to turn on. must plug and unplug for about 45 mins
Some components from the power source of your tv are dying and the embedded protection system detects that and blocks it to prevent further damage. Immediately stop trying to start it and call a repairman now, while the damage is still fixable, otherwise you will end up without the tv.
Jun 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Blue Pixels on left side of screen
Check the power connector. Also try a different source. make sure there is proper ventillation. Its time to get the TV checked by a technician for any hardware fault
Jul 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
Vizio 42 inch Lcd tv
You need an Vizio authorized TV repair guy to check out the problem for you.
Solutiondoct
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
LG 50PC5D 50 Plasma Won't turn on
If you check underneath the t.v there may be a button that you need to push. then you can use the remote to turn it on. took about 2 hours before I found it.
mine is located on the bottom left, right underneath the screen.
Dec 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sylvania SRPD442 42 in. EDTV-Ready Plasma
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Aug 09, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
