HELP..."ink cartridge not compatible" error message.
Ink Cartridge Not compatible.....what does this error message mean? the cartridge is the same as it always has been, and it has always worked before, jsut suddenly started giving this error message? any help??? please?? thanks~!!!
    Problem Solver:
  • 5 Answers
I had the same problem and solution was change the cartridge for a new one (My printer is a HP PSC 1315)
Posted on May 11, 2009
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Ink refill costco hp printer C4780
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena, the 2nd video provides suggested cartridge prep/handling instructions when you return the cartridge for refilling:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
If the new (or refilled/reman/compatible) HP 74, 75, 74XL, or 75XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. If you run into a problem where the ink cartridge is performing marginally and blocks printing (via the Red X), you can bypass the error message (usually only 1 time per clearing action):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. You can also run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test).....go to www.inkjet411.com for more information on your specific printer model.
Feb 16, 2013 | HP Photosmart C4580 All-in-One InkJet...
Printer Error Message
Yes, there a few items you need to consider with respect to HP 61 (or 61XL) cartridge errors messages on any HP Deskjet 1000 through 3510 printer model:
If you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore ink low, non-genuine, counterfeit messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this low ink phenomena.
If the new (or refilled/reman/compatible) HP 61 / 61XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. Ensure you press OK or Cancel up to six times to clear out the printer error log.
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Aug 24, 2012 | HP Deskjet 3052A Wireless e-All-in-One...
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
201 people viewed this question
k24674
jasbo
jasbo
