Question about Bissell 3750 Lift Off Bagless Upright Vacuum
High pitched noise
My Bissell 3750 Lift-Off Bagless will make a high pitch noise after running for about a minute. It still works and eventually the noise lessens a little. What is wrong with it? How do I fix?
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
Posted on Jan 09, 2010
When turing on the vacumm it makes a high pitch noise. what is the probem
Motor bearings probably have run out of grease. Units like that can go bad after use over time.
Aug 02, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
Makes too much noise {high pitchs] like the motoris spinning the belt to fast.
That noise usually means that the belt is worn or stretched and its slipping on the motor shaft. Replacing the belt is easy to do and you can get the belts for this model here:
http://vacbelts.com/bissell-style-7910121416-belt.htm
Oct 18, 2009 | Bissell 3590 CleanView Bagless Upright...
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
1,323 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
