Question about Vacuums
Cannot work out how to empty dust part (bagless model)
We bought a Hoover Pet Performance second hand but it has no manual. Using it is no problem but I'm stumped as to how to empty the dust part (its bagless) Help please! Thanks Jenny
Hi
A visitor today knew what to do and has solved the problem thanks!
Jenny
Posted on May 14, 2009
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 | Vacuums
Motor shut off
Try it half an hour later, does it run? If so it's overheating. Change your filters and empty the cup.
If it does not run it's likely a problem with the cord rewind. Some of those units had a recall on the cord rewind. To find out for sure find a local hoover service center and take it in for repair many times at no cost.
Feb 10, 2013 | Hoover Elite Rewind Pet Bagless Upright,...
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
How do I take out the inside to clean clogged stuff
Push it up and turn clock wise it will fall out in your hand, do reverse putting back
May 01, 2010 | Hoover U6630-900 WindTunnel Bagless...
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I purchased a hoover windtunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=724091
Generic problem for all Vacuums
I purchased a Hoover WindTunnel
Posted by billmar082 on Jun 30, 2008
I purchased a Hoover WindTunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the particles but the filter will not turn. I also haven't been able to use the pet brush for some time. The cleaner has not been used hard about once a week since it was purchased. I am not happy that this product has stopped working efficiently since purchased 6 months ago. Thank you Marcia Long Pottstown Pa
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I sorry you are having a problem with the Hoover WindTunnel Vacuum Model #U8361-900 but I never heard of a filter that you say is self cleaning and NOT turning. I have never seen a filter that turns inside the chamber, the dust and dirt basically go around and circulate around the filter and you can clean the filter by either brushing it off, vacuuming it off or using some type of brush to clean off the filter such as and old paint brush or if you have some type of blower system – that would work as well. You said your vacuum is less than one year old so I would contact your local factory authorized Hoover dealer in your area or to cal the cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
