Question about RCA HD52W56 52" Rear Projection HDTV
My TV was turned on, but you could not see the picture. We just heard the sound and within seconds it turned off completly. Now it does not turn on at all. My TV is an RCA HD 52W56
  • 1030 Answers
SOURCE: Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Posted on Nov 17, 2008
  • 8457 Answers
SOURCE: rca hd61w66 61 inch tv, when turning on you can
Ur power BD power board have burn capacitors,buy the deflection board too,have puff up capacitors.
Posted on Sep 29, 2009
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
Slinteriors
  • 8617 Answers
SOURCE: I have an RCA Projection TV. The model number is
replace the deflection board ITC222A deflecction PSB-260 is available from www.tvrepairworld.com
Posted on May 14, 2010
caroldon
  • 17130 Answers
SOURCE: I have a D52W20 RCA tv. The picture will go out
Possible errors in the main board , it can be due to failure of a solder joint in the set.
Remove the back panel and switch on the TV to work. when the fault appears then the main board can be tapped lightly to see if there is any switch on of the picture. If so the fault is confirmed and you must resolder the dry joints of the suspected areas.
Look carefully with a good lighting to check the joints specially the high voltage and the power circuits.
Some tips on these board issues: click on Board problems
Also check for Soldering tips
Posted on Nov 06, 2010
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, audio flickers on and off
THIS IS USUALLY THE MAIN TOTAL ASSY OR THE PANEL IS BAD.
Jan 30, 2009 | Televison & Video
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv won't turn-on
ITS THE PICTURE TUBE ITS BURNT OUT - OR THE GAS HAS LEAKED OUT ANYWAY U NO LONGER CAN USE IT
Aug 22, 2007 | Hitachi (3223424A)
No picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Dec 22, 2006 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
