Question about Refrigerators
ADMIRAL REFRIGERATOR admiral    m   ASD2120DRW               S  11677213YIKINSTALL A NEW COMPRESSOR BUT I CAN'T PUT THE WIRES IN THE CORRECT WAY MAKE THE NEW ONE WORKS , I NOW THE START ,RUN BUT THE COMMON CAME FROM  RELAY (HAS TO WIRES ) IN THE WALL OF REFRIGERATOR , BUT i INSTALL A 3 IN ONE KIK RELAY ,  REFRIGERATOR START WORKING BUT , WHEN  I TURN IT OFF FROM THERMOSTAT , DIDENT TURN OFF,      MYNOR_RAMIREZ62@HOTMAIL.COM THANK YOU
  • MYNORRAMIREZ Oct 14, 2007
    thank you so much
  • 473 Answers
The blue wire goes to the overload (common), the other two wires will go on either side of the relay.  If you have an orange wire put it on start.
Posted on Oct 13, 2007
Fridge admiral ac2224gekb stopped working
1 this is not compressor because it's starting and it's not starting realy because is part of compressor.
2 You my have problem mainboard or temperature sensor name of part thermistor work like(thermostat) cost less then mainboard
Nov 02, 2013 | Admiral 26 cu. ft. Side-By-Side...
Compresor not working it buzzes for 30 seconds and then the relay switches off
im an refrigeration engineer,the compressor windings are gone,new compressor needed
Aug 28, 2012 | Admiral 26 cu. ft. Side-By-Side...
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral refridgerator freezer works fine but cooler section not cooling. had ice in back of cooler section.
it may be a timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 also ...do not damage coils with freon in them
Aug 25, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
ADMIRAL REFRIGERATOR/FREEZER BURNED
admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Nov 02, 2007 | Admiral 26 cu. ft. Side-By-Side...
Freezer icing every 3 weeks
you have aclogged drain. remove the panel in the back of the freezer that exposes the evaporator you will want to shut the unit off too. next remove as much ice from the pan as possoble. use a hair dryer to help get the big stuff loose. now you will want very hot water and pour it in the drain pan. your going to make a mess at frist but you need to do it untill the ice in the drain is melted and the water will flow into the drip pan. make sure you cloan all the food drbris also. after it is clear put the back on and turn the unit back on. you will not get any more ice buildup as long as it stays unclogged. and the ice is from the defrosting of the evaporator.
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
