Question about RCA R52WM24 52" HDTV Projection Television
Tv turns on and off 3 times and then stays off
  • jabroni May 11, 2009
    my ge 52 in. turns on an off three times then stay off
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
MY TV KEEPS TURNING OFF
Check the belt of the vcr maybe are on bad conditions and don't make it's function correctly
Apr 12, 2010 | Sylvania 6313CB 13 in. TV/VCR Combo
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
My 40"samsung LCD turns on/off 3-4 times before staying on
You need to change the 1000uf caps in the power supply. only if you are handy with a soldering iron. Take back of remove psu. You will see them bulging at the top. Think there is 5 to change :)
Jun 16, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
