Question about Integra DTR-8.3 Receiver
No output to subwoofer per-amp
I have Integra DTR 8.2 receiver. I tried to connect it to 7.1 speaker system. They all work fine except the subwoofer. It seems that there is no output from the subwoofer pre-amp connection. I was able to connect the subwoofer with a different pre-amp I have and it is working fine.
I obviously enables the sub-woofer at the receiver setup screen. I set all the speakers to small size so low frequency below 80Hz will switched to the sub. Yet nothing.
Thanks in advance for your help
  • 1 more comment
  • ronenv May 20, 2009
    Thanks for your comment. As I said "I obviously enables the sub-woofer at the receiver setup screen" I also tried to reset/reboot the receiver (pressing video1 + standby power). Indeed, it rebooted and cleared all the configuration. So after reconfiguring, it still doesn't work.
  • Anonymous Mar 20, 2014
    no output from my sub-woofer. all the other speakers work fine. and I don't have a remote for it
    well how do you enable the sub without the remote if possible
  • 92 Answers
You may have to go into the onscreen menu and enable it,that shuld work
Posted on May 20, 2009
  • shawn rogge May 20, 2009
    i think its under the zone 2 out put.sometimes those jacks double for tw things
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
Bose acoustimas speaker output jacks not working
try to trace your problem inside the main circuitry of the jacks ( open it and see on the solder side of the Printed circuit board(where all the electronic components and soldered/welded if there are loose connections (small cracks... use magnifying glass if you have one) then solder them.
also check for the transistor amplifiers and output capacitors....
check also for the connectivity of all wirings!
Nov 17, 2007 | Tannoy Sensys 7 Speaker
Integra receiver clicking
You most likely have a power amp problem, disconnect all speakers and see if still does the clicking, if so you have an output amp problem
Apr 01, 2014 | Integra DTR-5.1 Receiver
HELP! Surround speakers not working with 5.1 material.
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
Integra DTR-8.3 Receiver Logo
431 people viewed this question
Top Integra Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
