Question about Gateway MX6920 Notebook
Gateway mx6920 powers on sounds like its booting but screen is bl
When i turn the computer on it acts as if it is going to boot up all of the components seem to work the cd drive sounds like its working but the screen never even lights up just black i changed the lcd inverter but still black screen i think it may be the power module but i want another opinion before i spend money on a part
    President:
  • 2,653 Answers
It's most likely your motherboard. It's really common with the MX series.
I'd pull the hard drive and sell the laptop for parts on eBay "as-is".
It's NOT the power module.
Or you could always swap the motherboard but in my opinion it would be best to just invest the money into a new laptop instead of this one.
Best of luck!
Posted on May 11, 2009
Well I was on my computer trying to finish my paper due for school and I saved my paper to my computer first then I wanted to plug in my usb so that I could save it to my usb and take it to school the next...
Sounds like there may have been a virus on the USB drive..
OR when you inserted the USB drive it shorted the usb port.
Can you boot into safe mode (F8)?
Can you get a windows disk to boot?
Please get back intouch if you can boot up either way.
If you cant, you may need to be looking for a repair shop
Aug 02, 2010 | Gateway GT5252 PC Desktop
When my Gateway 300S is powering up, it recycles.
If you repeatedly hit F8 key when the computer starts to boot it will open the boot menu screen. There should be an option to "halt computer on all errors". This should bring up the blue screen of death. It should give you something like
STOP: 0X0000007E, the a whole bunch of other numbers. after that it may display a file name. You can search the internet for STOP: 0X0000007E and the file named mentioned. You may be able to find a solution by doing this. It is usually caused by a bad driver or executing a bad command on Windows start up. You can boot the computer in safe mode from the boot menu and maybe repair the problem but it's a tough one to find. I'm trying to repair a similar Gateway computer. It doesn't list a file name and I'm pretty sure that it's a video driver or the onboard video card. The problem is Gateway is no longer in business and it's hard to find updated drivers I"m going to try to backup all the files on the drive and re-install windows and try to repair the drivers with more updated ones. The gateways are hard because they don't have slots in the motherboard to install anything but an old PCI video card. It may be time to think about a new computer soon.
Nov 14, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
I have a Gateway MX 3228 laptop that does nothing. I can hear a slight sound from the area of the hard drive when I turn it on. The battery is supplying some power as the button light illuminates when the...
If you get no display at all, it could be failed memory.
Find and open the memory slot, remove and reinstall whatever memory module you find and retry it.
Many systems I've seen will do absolutely nothing if memory is faulty; they do not give any POST beeps, displays or start to read from the hard drive.
The hard drive will spin up when power is applied but will not start their own self-test or look for the boot sector if bad memory is in play.
Good luck-
Oct 24, 2009 | Gateway MX3228 Notebook
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Gateway mx3215 freezing on init boot
Corrupted driver or faulty hardware perhaps.
May 08, 2017 | Gateway FPD1975 19" LCD Monitor
Computer will not get past the BIOS screen
it sounds like a problem regarding the POST process (power on self test) which is the first thing your computer does when booting up when testing the components that make up your system to make sure it has what it needs to start booting. which in your case could mean you may have a hardware problem. do you know what jumper on the motherboard you were trying with?
Try to reset your cmos by removing the cmos battery, waiting a few minutes, reinstall the battery and try to restart?
if possible post what system you have to get more details on how to reset your motherboard:
look for your system here:
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=510series.html
Sep 27, 2008 | Computers & Internet
Cannot reboot computer it will freeze everytime at the finnalizing stage.
Most computers set Harddisk as the default boot option. Go to BIOS setup(press del during startup) and go to boot options and changed it from there. It is either found on advanced setup or it has a menu of its own, depending on the BIOS chip.
Sep 18, 2008 | Gateway GWTF62603L3 MX6920 Series...
Gateway mx6920
try to remove your memory then use the eraser to clean up the tip of the memory then put it back try to turn in on
Mar 23, 2008 | Gateway MX6920 Notebook
Computer won't boot up...
booting files corrupted try to boot by inserting windows 98 bootable cd or windows xp bootable cd
Dec 03, 2007 | Gateway GT4016 Desktop PC
Gateway MX6920 Notebook Logo
158 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
