Question about HP Pavilion F1703 17" LCD Monitor
Power light flashes on and off and monitor will not power up
I have an hp pavilion f1703 monitor and when I try to power it on the power light just goes on and off and won't give me a screen. I hear my hard drive trying to do something, but can't do anything to get monitor to go on.
  • fasttechpc May 11, 2010
    First of all have you tried this monitor or your tower on a nother computer or monitor. Then if you did does the monitor blink on and off or does it go orange green orange green which is usually the monitor searching for signal.
4 Suggested Answers
  • 11 Answers
SOURCE: Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
Posted on Dec 25, 2007
budmrtn
  • 11361 Answers
SOURCE: HP Pavilion f1703 Monitor flickers on & off
Clean and resolder all four round inductors, check the caps, replace them if they have bulging tops (even slightly bulg). Check the transistors (c5707) for shorts. See pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 25, 2010
budmrtn
  • 11361 Answers
SOURCE: My hp pavilion F1703 monitor goes blank about every 30 seconds.
Thsi model has known problem with bad solder joints due to contamination, you need to remove the old solder on the four inductor leads, clean the leads eal well and resolder, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Al so look to see any one of the capacitors have bulging top, they should be completely flat top.
Posted on Jun 06, 2010
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
My hp f1703 monitor just turns off on it's own.
Common failure in this monitor is the poor soldering works on the doughnut (4) shape inductors in the inverter board, http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Feb 18, 2010 | HP Pavilion F1703 17" LCD Monitor
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1703 flashes on and off. Tried pushing F8 for 30 seconds - no result.
have you checked the power connecter at the back of the monitor?
is it the whole PC that is flashing on and off or JUSTr the monitor?
the F8 key when turning on a Windows based PC, will only take you to a screen to choose how to start windows, in Normal mode, safe mode, or commandline mode.
none of this helps a flickering screen.
try and change out the data cable (VGA cable, blue screw in plug) and the power cable if possible.
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1703 flashing orange monitor light what does this mean?
This usually means that it is not getting a video signal. Try checking the connections and make sure your video card is seated properly in the computer.
Jul 07, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
