Question about Intel Celeron D 2.8GHz 478-pin 533MHz CPU OEM (CPUSKCD280533)
Can u help me?
My new computer loads only to C:Windows/system/mup and freezes. Further checking reveals the message Invalid media reading C:
I figured out that the partition table must be fouled. When I put in my Windows XP home
disk it starts to load but I have no display.
It seems to me that the display in Windows XP must be disabled somehow. Even my XP recover disk when it loads has no display as the screen stays grey. How can I format this drive to reinstall the XP? Or should I just get a new Hard drive and start over? The computer is 6months old, 248mb ram, 2.8ghz hard drive. Last scan with Norton Symantec
showed no hard drive issues.
  • 51 Answers
You may insert the Windows XP CD and reinstall Windows XP just to be sure. Follow the instructions on your screen and format the C Drive. Make sure you install all the required drivers to make everything work.
If you are optimistic follow the following instructions:
This will help you attempt to repair your system (and not via the Recovery Console).
Insert the Windows XP CD and follow the instructions on your screen.
Then after a certain point, you will be asked for three options --
1. Install Windows
2. Repair via Recovery Console
3. Some other option I don't recall.
Select the first option.
Then again, follow the instructions on your screen and again the computer will ask you three options.
This time select the second one -- Attempt to repair the computer (Press R).
This should start the automated repair process. This has been observed to work most of the time, but in a few rare cases it doesn't work. So I suggest you try it if you have the patience. ;-)
Good Luck.
Posted on Oct 18, 2007
How do i fix message from webpage invalid pointer
Try using a different web browser like mozilla or chrome and check if the problem still persist.
Or
You can do a system restore.
I hope this helps!
Carlo
Thank you
Jan 01, 2013 | HEWLETT-PACKARD Computers & Internet
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
I have a sony vgn-fe780g laptop computer. I cannot load windows. The memory test good with windiag. The hardrive tests good. The computer hangs at loading the mup.sys file if when starting in safe mode. I...
Make sure your installation CD is ok by testing it in another system. You can use utilities in programs like Nero to scan the disk and make sure there are no read errors.
Let me know if this is of any use.
Best wishes,
Graemevm
Mar 05, 2010 | Sony VAIO VGN-FE780G Notebook
XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Apr 20, 2009 | HP Pavilion dv8235nr Notebook
How can the product key be wrong??
I would be extremely surprised if this turned out to be a valid copy of XP. Shrink wrap is easy to do. Someone has already used your product key which Microsoft has now registered to a different computer.
And yes, when you submit it the message is that it is invalid which means already in use by another computer.
Microsoft never gives the error message "this product code is already in use". They only say it is invalid.
I've installed XP tons of time and even had a few times where the license belonged to another computer. When that happened, the invalid error message is what I got.
I'll make another guess and say you did not buy XP from a computer store, but instead from an individual. A reputable computer store should be able to help you with your problem if you bought from one.
Honest1abe
Jan 11, 2009 | Microsoft Windows XP Professional
Video Drivers
The file “Windows/System/Drivers/mup.sys” is not actually causing the problem. It’s the next step after mup.sys that’s causing the computer to hang. That next step consists of the OS checking the registry files for plug and play devices.
Some causes are: new or defective hardware installed, corrupted registry, (caused by virus), defective or corrupted hard drive, just to name a few.
Try removing all devices attached to the computer like printer, web cam, flash drives, etc.
If your computer has a PCI or AGP graphics card AND your motherbrd has a VGA connector, remove the video card and use the one on the motherbrd.
If the above doesn’t work, try running “CHKDSK /P” from the Windows recovery console.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell OptiPlex GX260 PC Desktop
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
http://www.fixya.com/support/r601327-wipe_reboot_rio_carbon
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
Mowcius
May 22, 2008 | Rio Carbon MP3 Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Laptop won't startup HELLP!!!!!!!
what is the configuration of your laptop - i can't tell you the solution without knowing that
Jan 07, 2008 | Microsoft Windows 98 for PC
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Intel Celeron D 2.8GHz 478-pin 533MHz CPU OEM (CPUSKCD280533) Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
