Question about Lexmark X1270 All-In-One InkJet Printer
Where are print cartridges located in the Lexmark 1200 series so that I can change cartridge? Got printer at a sale and don't have manual.
    Problem Solver:
  • 6 Answers
I have a Lexmark X1270 and this is probably the same as yours.Lift the top (not scanner lid!) and with power on the cartridge containers will locate centrally for you to access,once located these coloured containers have a hinged lid,pull the lid upward to remove cartridges contained within.Hope this helps.
Posted on May 11, 2009
Scanning Pink
It could be due to your color cartridge. Try to do the clean cartridge function using the printer software on your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Try to scan again to verify that the print quality has improved. If not, try to replace your cartridge.
Mar 04, 2012 | Lexmark X1270 All-In-One InkJet Printer
Wont print
It could be that your cartridges needs some cleaning. Try to follow the steps below to fix the problem:
  1. Make sure your printer is connected to your computer and is turned on.
  2. From your computer, go to Start menu.
  3. Go to Programs or All Programs.
  4. Go to Lexmark 1200 Series folder.
  5. Select Lexmark Solution Center.
  6. From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt. After successfully printing the page, try to print your document again to verify that the problem is fixed.
If that doesn't help, you can manually wipe the cartridge nozzles with a slightly damped paper towel. Then reinsert the cartridges and try to print again.
If the problem continues, then it could be a faulty cartridge. Try to insert a different known working cartridge or better yet a brand new genuine Lexmark cartridge. Lexmark products work best with original supplies.
I hope this helps. Thanks.
Nov 19, 2011 | Lexmark X1240 All-In-One InkJet Printer
My printer only prints in color I can not get it to print in black even after I change the black cartridge.What is my problem?
Try to open Lexmark Solution Center application on your computer and check if the software recognizes the ink levels of your cartridges. Go to Start menu > Programs > Lexmark 1200 Series folder > Lexmark Solution Center.
You can also use the software to clean the cartridge nozzles for possible dirt and clogs. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark X1240 All-In-One InkJet Printer
Have color cartridge in, bottom tab removed and printer will not print in color
Print quality issues could be due to clogged cartridge nozzles. Please follow the steps below to clean the print cartridge nozzles:
  1. On your computer, go to Start > All Programs / Programs > Lexmark 1200 Series > Lexmark Solution Center.
  2. From the Maintenance tab, select Clean to fix horizontal streaks.
  3. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them.
  4. Try to print again.
Jul 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1290. I have been using the black cartridge....its still got ink in it and I am getting a Cartridge Missing Error. I have cleaned the cartridge and still no luck. What else can I do to fix the...
Try to clean the cartridge nozzles using the Lexmark Solution Center on your computer. Launch the application from All Programs > Lexmark 1200 Series Printer > Tools > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal lines. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Once done, try to print again and check if black is printing properly now. If that doesn't help, try to insert a different known working black cartridge to determine if the other is fautly.
Jun 15, 2011 | Lexmark X5150 All-In-One InkJet Printer
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark X4530 left cartridge incorrect
You must upgrade your firmware on your printer.
Lexmark has a technical support bulletin :
Cartridge Numbers 23 and 24 Are Not Recognized on X3500-4500 Series Printers
Jun 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 1200 series printer won't print
Call me and I can walk you through what Lexmark just walked me through with the same problem
Laurie
732-356-7256
Jan 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
How to change lexmark Cartridge
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
