Question about Whirlpool Duet GHW9150P Front Load Washer
Washer leaked out front now will not perform any function/ drain
I placed a large comforter in the washer which caused it to leak thru the front and i paused it and turned to drain function. the washer will not shut off or drain
  • 51 Answers
THIS WASHER ISN'T DESIGNED TO WASH SUCH ITEMS, YOU NEED TO REPLACE DOOR LATCH AN MMC
Posted on May 16, 2009
My washer is leaking when draining very small leak what can i do
Start with inspecting the entire lenghth of the drain hose for any type of pin hole or abrasions that could be the source of your leak.
If the leak seems to be coming from the inside of the machine, take a putty knife or something similar and insert it between the front panel and the top panel that the lid is connected to about two inches in from the edge of the side panels and you should feel a fastener, push inward or towards the back of the machine, you will have to push hard, this will seperate the top and front panels, lift up on the front panel and remove it, now inspect the inside of the machine and try to locate the source of the leak, you may have to run the washer thru different cycles(fill,drain,spin,etc.) to see the leak source.
Pay close attention to the pump area for the leak, this has been a source of leaks in the past, with a plastic pump housing, they have been known to develope leaks by way of holes worn thru the plastic housing!
GOOD LUCK !
Aug 08, 2010 | Maytag LAT3600A Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
I have a Whirlpool Ultimate Care II LSQ 9010PG and it was leaking last time I ran a load. It seems to be coming out the front end. I check the discharge hose and it is well into the wall and the machine....
If the leak is coming from under the front of the washer, this is commonly caused by a leaking drain pump or drain hoses. These pumps are not serviceable and will require replacing.
If the leak is coming from the back of the washer, this is commonly caused by a leaking water inlet valve or associated dispenser hoses.
If the leak is coming from under the center of the wash tub, this can be caused by a bad tub or cracked outer tub shell. If the seal is leaking, tell-tale signs of water marks will be visible on the gearcase (transmission). If the tub is cracked, it can be temporarily repaired with 2 part epoxy, but will ultimately require replacement (not a common problem).
Now...if the leak begins when the washer starts to fill and is a huge gush of water, this is caused by the air hose coming loose from the air dome. The air dome is a small plastic air gap on the lower right hand side of the wash tub. There is a small rubber air hose that connects to it and runs all the way to the pressure switch inside the operator console (located behind the load level selector knob). This is what shuts the water off at the appropriate water level. If the hose comes loose, there will be a huge gush of water pouring out of the wash tub (air dome) when the tub reaches about 1/4 full.
In any case, you will need to remove the outer washer casing to access the interior. Follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To re-install the case, follow these steps:
1. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If any of these symptoms sound familiair, and you need addtional assistance, please let me know. I hope you find this information helpful.
NOTE: If the drain pump IS the problem and you need to replace it, pull the drain hose from the standpipe at the wall and use a wet/dry shop to pull a vacuum on the line. This will drain any residual water left in the drain lines. The pump is easy to replace. Simply loosen both drain hoses, pop the two retaining clips that hold the pump in place, and pull it off the drive mot shaft.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer leaks when it's starting to fill.
Can you explain where the leak may be coming from? Is this a small leak or a huge gush of water?
Aug 01, 2009 | Kenmore 22422 Top Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
Clean the pump and hoses......if that does not help need new pump
May 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks during wash cycle
Taking a top loader apart is simple if you follow these steps:
The drain pump is the most common cause of leaks. It will be located in the front of the washer. Check the drain hoses and clamps as well. If the pump is leaking, it is NOT serviceable and cannot be repaired. It must be replaced.
Check the wash tub to ensure there are no cracks causing the leak.
To reinstall the outer case and components, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
4. Reinstall operator console.
This is not a difficult repair, but if you have questions, please let me know.
Apr 27, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Washer leaks on on the floor when using a large load setting.
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
