Question about MSI K8MM-V Motherboard
M/b cannot recognize SATA HDD
I am using MSI [K8MM-V] motherboard with an AMD processor and VIA [VT-8237R Plus] chipset. I'm facing regular problems with SATA. My system does not often recognizes SATA and POST does not transfers control to XP. All I get is a WHITE SCREEN with HDD LED solid ON. I restart my computer. Enter H/w SETUP. Disable SATA and, then reboot --- sometimes it works and sometimes it doesnt. I have two HDD i.e. 1 IDE from where XP boots. SATA is connected on SATA-2 port. PLEASE HELP!!!
    Problem Solver:
  • 5 Answers
This is common to other mainboards, the SATA controller have it's own BIOS, but it only works correctly using two identical SATA HD's at same time for data protection purposes. If you have a free PCI slot there are expansion cards based on VIA chipset VT6421 with 2 internal SATA ports, other external and one IDE. See one here
Posted on May 11, 2009
  • Rinku
    Rinku Apr 14, 2014
    MY DESKTOP PC HAVING 500GB SATA HDD WHICH IS NOT DETECTING BUT I HAVE CHANGED THE SAME POWER AND DATA CABLE TO DVD-DRIVE IT IS DETECTING WHAT IS THE PROBLEM
I have MSI K8MM-V MOBO w/VT8237R Chipset. WIN XP 2 gig ram I have a WD7501AALS HDD to replace a WD1600JS-22N HDD Both are SATA drives Problem: The BIOS nor the POST will recognize the WD750. I have...
Hello, You need to right click on to my computer>Manage>choose disk management, you should format the new SATA HDD there.
If that will work for you that is good but if not, i thing you should updated the BIOS and you have to make sure that you get that update to MSI website. if you are not familiar w/ that asked some one who know how to flash BIOS. it is risky if you are not familiar doing BIOS update!!!
Mar 04, 2011 | MSI K8MM-V Motherboard
I have MSI via k8m800 vt8237r chipset based board and amd athlon x2 dual core 4600 cpu ccan i suppor 1tb sata hard disk
some of the motherboard select the kind of devices that will work for them, try to test your sata hard disk with another system if it work then try to change the board. or get another system that will support your sata. thanks
Jun 12, 2010 | MSI K8MM-V Motherboard
HOW TO INSTALL WIN XP ON SATA HDD ON MSI K8MM -V M/B
If your copy of Win XP does not recognize the SATA drive (i.e. Early copy of XP) you will need to use the F6 option and load the SATA driver that came with the MSI mother board.
Mar 24, 2010 | MSI K8MM-V Motherboard
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
Computer does not work first.
Does it power up if it does do you hear a beep on post screen, Please Briefly explain what is happening my email : colin.gila@wits.ac.az
May 08, 2009 | MSI K8MM-V Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Problem with audio driver
haii,
Im using ms 7173 ver 1 motherboard and via chipset VT8237R and AMD sempronprocessor. I have problm with my audio driver so pls help me for downloading the corresponding driver.
Thanks
Sajeesh
Jul 08, 2008 | MSI K8MM-V Motherboard
Pls help for downloadin via vt8237r audio driver for msi 7142 motherboar and amd processor
pls help me to download vt8237 plus audio driver / that msi m/b driver...pls urgent...
Jul 07, 2008 | MSI K8MM-V Motherboard
MSI K8MM-V Motherboard Logo
675 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
