Question about Gateway 7330GZ Notebook
I need to replace the backlight on my laptop
Gateway 7330GZ, how do you remove the display
    President:
  • 2,653 Answers
Majority of the time it's NOT the backlight, it's the inverter. Who told you that it was the backlight specifically?
Virtually every lcd is the same procedure. Just remove the screws around the lcd, some are hidden under the rubbers, and CAREFULLY pry the plastic surrounding the lcd. It's basically common sense. Just take it apart....CAREFULLY.
That's about it, really.
Posted on May 11, 2009
Gateway 7330 gz shuts off or monitor flickers
This probably isn't a driver problem. Your backlight power cable is probably loose. You can tell by getting a flashlight and looking closely at your monitor while it's powered on. If you can see your desktop items then it's a backlight cable problem. I had the same problem with my Gateway. You can remove the front bezel from your display to get to the cable. I just pressed mine up into the display as much as possible and put a little hot glue on it to keep it from backing out. I never had the flickering problem again. Good luck.
Jan 28, 2013 | Gateway 7330GZ Notebook
A techie told me that the reason my Gateway 7330GZ notebook will not power on is a faulty power distribution IC on the motherboard. The part is impossible to find in my part of the globe (Nairobi, Kenya)...
You need to replace the motherboard. This may not be a cost effective solution.
It may be better to put your money towards a new laptop which will be faster and most likely slightly more than the cost of repairing the Gateway.
You can remove the hard disk from the Gateway and put it into an USB hard drive adapter case and then use it as an external USB hard drive for backups and data transfer.
May 23, 2011 | Gateway 7330GZ Notebook
The momentary switch on my Gateway 7330GZ laptop is defective. If I can slide it to the proper location, it will work. How do I remove the display portion to access the screws to remove the top panel and...
Here is a video on how to open the monitor on a Gateway notebook, although if the switch isn't working anymore I assume there is a part of it broken inside and you might need a replacement.
Dec 07, 2010 | Gateway 7330GZ Notebook
I have a gateway 7330GZ and I need to replace the CMOS Battery. Where is it located and how do I get to it?
the battery is located at the motherboard. you will see a big round battery like a watch battery but 5 times bigger,
open the CASE and you will see it shinning !! you need a tyny screw driver to remove the battery. you can get a replacement online by typing the model of the battery o take it to CVS they carry it
Oct 08, 2009 | Gateway 7330GZ Notebook
Screen brightness often flickers
Your problem could be a faulty backlighting panel or the power connector for the backlight needs reseating.
There are two connectors on the LCD that are connected to the motherboard, one for the video signal and the other for the backlight power supply, reseat this connector and hopefully your problem will be fixed.
Dec 31, 2008 | Gateway 7330GZ Notebook
Backlight doesn't work. How much to replace? Can I fix if novice
Backlights are not generally expensive but I wouldn't suggest you repair it yourself unless you've opened up pc's before....you'll need a service repair manual to do it yourself as, at the very least, you'll have to remove the screen bezel (usually 4 screws) and then detach the screen from the hinges (again usually 4 screws).
I would suggest getting a couple of quotes from repair centres.
As far as backlight goes it either works or doesn't (like a light bulb) sporadic use usually means a bad connection rather than a blown light but it would still need to be opened up to check the connections...again needing a service manual and a technical person
Nov 16, 2008 | Gateway 7330GZ Notebook
7330GZ Gateway laptop keyboard doesn't work
There is one thing you can try. Uninstall the drivers for the keyboard from the device manager, then reboot. The machine will find the keyboard and reinstall the drivers automatically. If this doesn't work, then I'm afraid the Shift key function has failed and the keyboard will need replaced in order to fix it.
Aug 25, 2008 | Gateway 7330GZ Notebook
Backlight problem
After doing much research, as I have different but screen related issue the Inverter Circuit Board is bad and needs to be replaced.
Mar 29, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ laptop. Good battery, good Ac Cable will not turn on?
The system board on the laptop needs replacement.
Hope this helps :)
Nov 25, 2007 | Gateway 7330GZ Notebook
Computers & Internet Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
