Broken stuck CD drive
The CD drive for my Packard Bell iMedia J2422 Is stuck open and will not close past 3/4 open . I think i may have knocked it . But i cannot remove it . I have opened up the computer and the CD drive wont slide out the front or through the back
  • Gardner949 May 11, 2009
    The screws were definitely out. The emoving the panel seems more likely . But i have no idea how to do that on my desktop :L
  • Gardner949 May 13, 2009
    thanks very much . I was able to open up the front casing and remove the broken drive and replace it with another.
  • 400 Answers
Make sure it's not being held by screws on both sides.
Posted on May 11, 2009
  • 1 more comment
  • Fabio May 11, 2009
    Might also be some clips you have to press in order to release it.
    some computer cases you have to remove the front panel casing first.
  • Fabio May 12, 2009
    So you have removed both computer casing side panels ,removed all the screws on the CD Rom and disconnected the cables from it?
    After looking at your computer box from Packard Bell website you will have to remove the front panel.
    To remove the front panel lift the computer up so you can see under the front panel and see if it has a clip or lever that you can press towards you to remove the front panel.
    Another way would be too look inside the computer case and see if there are any black clips holding the front panel casing to the chassis(the steel internal computer frame) or maybe screws.
    If it's difficult to remove the front panel then remove the floppy drive or card reader too as they can make removing the panel even harder.
    Are you able to open it ?
Just bought a new stationary packard bell imedia. can't find the way to open the cd drive ? no button or nothing...how do you open this?
Depending on the OS you use it can be opened fairly easily. If you're using Windows XP or higher (I think) then just click on My computer. Then right click your cd drive. Should be an eject selection that will open the cd player. As for the physical button Im not sure where it would be located but sometimes they place them on the keyboard.
Aug 17, 2011 | Computers & Internet
I have a Packard Bell Imedia desktop not sure of the model. It was working fine until recently, I switched on my pc and after the boot screen "NTLDR is missing Alt Ctrl Del" message appeared....
Remove the hard disk and attach it to an USB hard drive adapter and then connect it into the USB port of a working computer. This computer will detect the hard drive as an external storage device, then you can open the various folders and files to copy your files to this computer or burn your data to a CD/DVD disc or USB flash drive.
Return you hard disk back to your Packard Bell so you can reinstall Windows.
Aug 10, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
I need a manual for my gigabyte ga-t671mg motherboard so that i can connect the on /off switch
There isn't a manual available for it, as it is an OEM motherboard in pre-built PCs BUT I've the same motherboard in a Packard Bell iMedia J2422 (now in a BitFenix Colossus case!). You connect the power to the bottom left, reset top left, h.d.d led top right, power led bottom right into the Front Headers (F_Panel) - which is located on the bottom right hand-side of the motherboard. My board has writing underneath the header telling you what connects where, maybe yours does too? Hope I've helped.
Mar 24, 2011 | Intel Motherboard
My computer stopped working some time ago, and I was pretty much certain my hard disk had died (SATA), so I bought a new Hard drive (SATA) and booted my computer....the bios didn't detect the hard drive,...
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 18, 2010 | Packard Bell Computers & Internet
How to add another hard drive to my pc desktop
if you have a 3 plug ribbon, plug it into the new hard drive and plug in a power supply plug
Jun 18, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Need new master CD to work old desk top packard bell, I have CD's but do not work. Number on CD's are 6841210301 to 6841240301.
Packard Bell IMEDIA 5109 I assume ?
you would need to order them from packard bell, but why bother, Reinstall Your os and download all required drivers from
http://support.packardbell.com/uk/item/index.php?pn=P480410201&t=2006
Sep 10, 2009 | Packard Bell Computers & Internet
IMedia B2217 PC: DVD lid flaps down but drive
There should be a little pinhole located under the door on the bottom of the tray. Push a paperclip in the hole to get the tray open. After the tray opens, close it and see if you can open it normally, if not it's broken and needs replacing.
Apr 26, 2009 | Packard Bell Computers & Internet
Easynote mv35-202 locked at f2 screen
you have to set the hard drive first if there is any one detected if not there is bad hard drive and you have to replace it
Jan 02, 2008 | Packard Bell iMedia SL 9553 (P660401806)...
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
