Question about Freezers
Temp only gets down to 39 degrees. The door seems to be shutting correctly. I hear the door suction being applied. It looks clean around the door. It's a Frigidaire stand up
    President:
  • 1,136 Answers
Hi, Is this a self defrosting freezer? If so, check and see if there is any frost build up on the rear evaporator panel. Check and see if there is an ice build up around the defrost drain. Couple of ideas for you. Please let me know if you find either of those or if I can asssist you further.
Thanks
Vic
Posted on May 11, 2009
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Correct suction line pressure
If it is R22 then it will be about 11psig on the suction side. This should give you a -18 degrees across the coil.
Jun 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Problems with an older Fisher Isotemp plus 98 model, the defrost circuit is not working correctly. The temp is normally around -20 degrees celsius and the temp is now at -08. I have manually defrosted the...
Noah had one of these in the ark...he did a full defrost(left it for 24 hours with the doors open then cleaned the vents/drains)and his was fine after that,hope this works for you.....also check door seals for tight fit all round.
Apr 06, 2010 | Fisher Scientific Freezer Isotemp* Plus...
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
Freezer runs continuosly, temp on control reading -8 degrees,unit never shuts off. also get alot of condensation on doors seems door heaters are not working.
Lets start with why it wont shut off. This seems most likey the thermostat. Turn down the t'stat to 1. if it doesnt shut the compressor off then recommend to replace t'stat. If you do defrost the whole freezer so that when you turn it back on it should take care of the condensation on doors
hope this was helpful
Mar 12, 2010 | Freezers
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How to tell if you have a bad suction valve for ac compressor?
Hey there. First question I have is if you have a heat pump or straight ac. Straight ac is easy to diagnose. Your suction pressure will be high, your head pressure will be lower, not sure how clean your condenser coils are so its hard to say how high. Your amp draw on your compressor will be lower than normal. Also, when looking at the suction pressures, you have to keep in mind what temp the air hitting the evap coil is. If it is warm, that will make your suction pressure go up. Another way to check the vavles is to hold the suction line at the compressor when you shut it off. If the temp goes up the second you shut it off, this tells you the hot gas is leaking through your suction valves. You can also try to pump the system down, then shut it off and see how fast the pressure builds back up, this will give you and idea how fast it is leaking through. Let me know if you need any thing else, I'll be here.
seth
Jun 26, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
51 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
