Question about Ricoh Aficio SP C410DN Laser Printer
Color Laser Printer prints a streak
A single yellow streak is going thru every page. Does this mean I need a new fuser, drum or something like that? I am not that familar with Ricoh. If its a parts problem, that I can install, I wiould like to try it myself.
Thanks!!
  • 95 Answers
Usually a yellow streak would mean the yellow pcu needs to be replaced. You can order pcus from a dealer and put it in yourself.
Posted on May 20, 2009
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
http://www.laserquipt.com/support/idx/26/452/article/Toner-Smearing-Issues.html
Mar 25, 2010 | Brother MFC-9440CN Laser Printer
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Oct 23, 2007 | Xerox Phaser 7700 Laser Printer
DELL 3000cn Printing Problems
switch off the printer then switch on again whilst holding the UP and DOWN menu scroll buttons simultaneously.
Then you can go to a TEST PRINT area and print off pages of idividual colour.
If the streaks appear on ALL prints its likely to be the laser unit. If the streaks only print on the COLOUR sheets ( not BLACK) then the problem lies with the drum or the transfer belt.
Remove the drum and turn it manually with the gog at the side and give it a clean with a soft LINT FREE cloth, do the same for the transfer belt and then you may have to run a few test prints to get it all reprimed but you should be OK.
Oct 18, 2007 | Dell 3000cn Color Laser Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
539 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
