The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
SOURCE: In my GE Performance refrigerator side-by-side Ice
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
