Question about Gateway VX930 19" CRT Monitor
Swivel base removal
Can I remove the swivel base from a Gateway VX900 monitor? I would like to lower the monitor by a few inches so my duel monitors are at approximately the same height.
  • 73 Answers
In the back of the swivel there is a small release lever... push down (?) then with other hand hit the swivel base towards back, then lift unit up.
Posted on Jul 24, 2009
How to remove base from gateway hx2000 monitor
You need to find the original instructions for putting the monitor together, or you could accidentally break the base from the monitor if you attempt to remove it the wrong way. Try Google.
Jul 11, 2014 | Gateway HX2000 20" Monitor
My monitor stuck down and i cant move it up the display solutions
You can remove the base and also see if debris is lodged between the back plane and the swivel head on the base. If you look carefully the cover snaps in place with plastic tabs. Once this is removed you can extract the screws that hold the base on.
Sep 25, 2010 | Samsung T220HD LCD Monitor
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
Removal of Base from Monitor
it's little trickey....u need to try and use little force and twist it to left or right and just pull it out....
dont use any tools it can damage it...
push it little forward / backward ...left /right...twist pull
Dec 17, 2009 | HP Compaq S9500 (Silver, Carbon) (Carbon,...
How to remove back panel
there might be screws behind the foot. remove the foot base first...then look to see. alot of these screens are pressure tab case fasteners.they use screws to lock in the cover. after that a smakk flat screwdriver along the lower sides will reveal is the cover is tab fixed .\
good luck
May 18, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Gateway LP2417 monitor won't work horizontally
I had the same problem on both of my LP2417 monitors. It turned out that there was a swivel software installed that was causing the problem. I found it in my taskbar and it didn't work when trying to swivel the monitor so I went into my control panel, add/remove programs, found the offending software and uninstalled it. After a reboot I was able to control my monitor swivel with my built-in Windows desktop preferences.
I'm sorry I don't recall the exact software name (its been a few months) but it shouldn't be too hard to find.
Apr 05, 2009 | Gateway 24" Widescreen Flat Panel TFT LCD...
How do I remove the base of a Viewsonic VX900 monitor?
actually you will be having a projection which locks into the slots of the monitor..
you need to apply some pressure to remove them out of the slots
Jun 18, 2008 | ViewSonic VX900 19" LCD Monitor
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Remove stand
we need picture of it, if your not talking about the swivel base.
Dec 02, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Disassembly of case
This is for a Viewsonic VX900. The bottom bezel with the button unclips.Unplug the connector, and put aside. ( Dont pull on the wires) Then there are two screws that are removed, and the grey frame around the monitor comes off next. Then remove the 4 bottom screws, and the two top tiny screws and the LCD comes away from the back. Remove the shielding, and replace your components. Good Luck !!
Sep 01, 2007 | ViewSonic VP920b 19" LCD Monitor
Gateway VX930 19" CRT Monitor Logo
215 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
