Question about Maytag Dryers
Maytag gas dryer model dg482
Dryer is taking a very long time to dry laundry.5 hours to dry towels.Is it worth fixing?Dryer is about 18 years old.Looks new,is it worth fixing?
  • 156 Answers
SOURCE: Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Posted on Mar 03, 2008
  • 3 Answers
SOURCE: NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
A lot of times this is due to the lint build up in venting.If its clogged it will take forever to dry the clothes. it also can clog on the vent where it comes either out of the roof or side of the house depending on where its vented Check to make sure its clean of lint.
Don F
Posted on Jul 09, 2008
appldoctom
  • 311 Answers
SOURCE: Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Posted on Jan 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: Maytag dg482 gas dryer won't heat
pilot safety most likely. most of these older units had a mercury bulb safety simular looking to a thermocouple.
Posted on Jan 25, 2009
crayzeetrayn
  • 837 Answers
SOURCE: not dry laundry
No I understand that .. Is your dryer 220V electrical source? If so it sounds like you have an electrical problem with the voltage supply to the dryer itself. I for some reason the dryer is only getting 110V that will allow the drum and dryer to function but the heating element will not .. You may need to talk to an electrician if you are capable of doing that yourself
Posted on Mar 27, 2009
My maytag dryer takes almost 2 hours to dry 1 load of laundry
I would try cleaning out the dryer lent from the exhaust duct from the dryer and also the duct to the outside of the house. Lint also collects inside the dryer. It may worth cleaning out behind the lint filer through to the exhaust duct.
Regards
yourlawschool.com
Jul 08, 2011 | Maytag PYE2300AY Electric Dryer
My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Maytag gas dryer model MDG9420BWW takes over 3 hours to dry towels. any suggestions for a fix.
there could be a few things going on here,,,
first the simplest, make sure your exhaust for the dryer is clear and you can feel a good amount of airflow.....
second,, try to peek inside the dryer, often does best frombehind,,, make sure during start up you can see your ignitor glowing ,,, if it does listen for a decernable click,,, tha would be the gas valve,,,
no glow....no go
no clunk..coils junk
Oct 30, 2009 | Dryers
Maytag atlantis takes hours to dry one load.
Most common problem is something blocking the venting process, either somewhere in the vent tube itself,,, or somewhere in the venting system inside the dryer, like maybe the blower fan.
Mar 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Jan 08, 2009 | Maytag Dryers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
187 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
