Question about Hitachi RAS-09UH Air Conditioner
When I start the AC the power switch trips
HITACHI WINDOW Airconditioner
    Problem Solver:
  • 7 Answers
Change your mcb and checked your voltage and compressor
Posted on Jul 29, 2010
Ac won't turn on it just clicks.
Hitachi DC Inverter Scroll Compressor have a startup problem. when i start the unit the compressor start a voice of " Tak, Tak , Tak rasie and after 30 Second the compressor trip, after few minutes the compressor again try to start and again Tak, Tak, raise and compressor trip. please somebody help me about this issue.
Jul 29, 2013 | Honeywell ER150B Air Conditioner
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
I need the user manual - hitachi logicool i window ac with remote
what are the functions of remote control for hitachi window ac logicool
Jun 10, 2009 | Hitachi Heating & Cooling
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Hitachi RAS-09UH Air Conditioner Logo
141 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
