Question about Xerox Phaser 8400 Laser Printer
Fault 37,002.47:70063 thanks - Xerox Phaser 8400 Laser Printer
  • 3 Answers
Insufficient AC Power Can Create 37,002 thru 37,008 Errors.
ENSURE AC POWER IS ADEQUATE FOR THE PRINTER
AC power supplied by power sources such as uninterruptible power supplies (UPS’s) or DC-to-AC inverter systems may not supply enough current to properly power up the printer. In such cases the printer may produce a printhead jet-stack or reservoir heater disconnect error 37,002.47.
Mel
Posted on May 12, 2009
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hi thanks for any help! While watching the tv, the screen went black. I can hear the sound and can pull up the menu for the channels. Any ideas? Thanks!!!
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 06, 2015 | Televison & Video
Please!!!VSD fault 7 and VSD fault 1 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw. thanks!
Vsd fault 7 is a fault with the hall effect sensors inside the motor, more than likely they will need replacing.
Sep 10, 2014 | Air Tools & Compressors
What is a p0307 code on a dodge truck 1500 5.7 hemi 2004 the truck is missing on one cyl.
P0301-P0308....2T catalyst........2004-05 Ram...Cylinder 1-8 Misfire Detected Conditions: Any time engine is running and the adaptive numerator has been successfully updated. When more than 1.5% (300M, Magnum), 2% (Durango, Ram), 2.5% (Durango LEV, Ram LEV), misfire rate is measured during 2 trips, or with 10-30% misfire during 1 trip. 3 good trips required to turn off MIL. Possible Causes: ASD relay output 2 circuit fault Injector control 1 circuit fault Coil control 1 circuit fault Ignition wiring, spark plug, or ignition coil fault Fuel pump inlet strainer plugged Restricted fuel supply line Fuel pump module fault Fuel pressure leakdown fault Fuel injector is damaged or has failed Engine mechanical problems exist PCM has failed. Hope this helps you. Thank You for using fixya.If you like this solution please rate it....Thank You, iluv2fish....Ray
Jun 24, 2010 | 2004 Dodge Ram 1500
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Mobilty scooter fault
i have a shoprider mobility scooter has soon has i turn on it goes about 5 yards and stops and the alarm comes on i think it has something to do with the brake system could anyone advise me on what it could be thanks
Mar 28, 2009 | Health & Beauty
Activation code for vbagx
unlock code / master code - 3752461055
Please don't forget to rate this solution.
Jun 22, 2008 | Nokia 6600
Xerox Phaser 8400 Laser Printer Logo
393 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
