Question about Kenmore 24032\24036 Top Load Washer
Kenmore 20842 won't spin or aggitate
The washer fills, drains, moves through the cycle just won't aggitate or spin - the basket does not move
  • 43 Answers
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
Posted on May 12, 2009
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
305 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
