Lines freeze in central air unit
I have a central air unit and the lines keep freezing. what are possible problems/solutions i can do. i'm not real handy but can follow instructions. i won't deal with electricity though.. far to dangerous
  • 520 Answers
If you are not certified to do H V A C then I highly recommend that you call in the pro's. However there is something you as a homeowner can do. Start by checking the air filter. if it is too dirty it will slow the air flow across the coils and cause the coils ti ice. The line freezing is a sign that your coils are beginning to ice or already have. This is also true if the coils are dirty. You can check this by removing the air filter and using a flashlight to look up inside of the air handler. If they are dirty then you can clean them with a solution of water, mild dish detergent and a soft bristle brush. Be sure to rinse them thuroly. If this does not fix the freezing problem then you may very well have a small leak and need to have some refrigerant added. hope this helps. Good luck.
Posted on May 11, 2009
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
My air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
Jun 25, 2009 | Heating & Cooling
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Neither Roof Air Works
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Dec 31, 2008 | Dometic Rooftop RV Air Conditioner
Central air unit
Make sure you let the blower run for a while after it freezes to make sure there is no more ice. Then run the unit. Check the refrigerant lines the large copper line that has insulation on it should be cold to the touch. If it runs for 10 minuits and is barely cold or warm you are low on refrigerant. If its starts out nice and clod then check your filter and retun ductwork for blockage you should not have noisy return air vents or that can indicate you have too small a return.
Also are the outdoor unit and indoor coil a match? Same tonage?
Is the furnace big enough to handle the tonage? (fan size)
Aug 17, 2008 | Coleman Propane Forced Air Heater...
Air conditioner freezing
Check your filter in the furnace, Then check the coil to make sure it is clean. If neither of these two solutions fix your problem you may be low on refrigerant.
Jul 22, 2008 | Samsung AS18A6RB Air Conditioner
Home central air conditioning unit
check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
Jun 09, 2008 | APC Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
