Question about Alpine SPX-17MB 300 Watts MIDBASS Speaker Car Speaker
Bass speaker start up noise
We recently had 2 10" bass speakers installed in a Honda. Three seconds after we start the car, the bass speakers make a loud noise prior to the radio starting. At that point the bass speakers play fine. What is the problem?
  • anne845 May 11, 2009
    Thank you! We will certainly look into this and see if this solves the problem. I'm glad to know it will not harm the speakers. It IS VERY irritating. I almost have a heart attack when I am in the car when it occurs. Luckily, it is my daughter's car and I rarely ride in it. I do want to try and get it fixed though. Thanks again!
  • 655 Answers
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
Posted on May 11, 2009
Which are the best speakers i should use with my sony amp 222
Rockford is great for bass and your two way speakers. Alpine still controls the three way speakers that I would suggest for wanting the strong vocals with less bass. Too much bass bad so I would ignore most input from "audio" guys. They always over build the bass side, balance is the key.
Jan 22, 2013 | Sony XM-222 Car Audio Amplifier
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
I had a set of computer speakers (Altec Lansing BX3). My wife plugged a heater into the surge protector and later yanked the heater plug out before turning it off. Computer went into some freaky cousin of...
Maybe the capacitor in the power supply burned upon unplugging the heater. The power supply is a coil with iron core, next to it, there should be a rectifier and a capacitor. If the capacitor is burnt, the powersupply will still be working, but there will be noise on the line, the 50 Hz that comes out of your wall outlet. Capacitor of the same value can be bought for small change but has to be soldered in.
Nov 15, 2010 | Audio Players & Recorders
Noise/No Bass in Delco Systems stereo
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Jul 05, 2010 | Car Audio & Video
Kenwood KVT-815DVD Unit only buzzes
I bought a Kenwood KVT-815dvd player and got everything hooked up to only find out that it had a security code. The problem now is that I got it from a pawn store and they did not even know that it had a security code on it. So is their a way I can bypass they password or just reset the whole unit so that it does not have one. Also, where is the memory for this unit?
Thank you
Nov 19, 2009 | Kenwood Excelon KVT815DVD Car DVD Player
Saturn speakrs not working, Bass hits though
you probably blew them up,they are junk speakers and cant take much and then they die,its common,replace them
Sep 30, 2009 | 2005 Saturn SC1
Subwoofer problems
check your power or ground cable. this normally happens because it is not getting enough power
Jan 10, 2009 | Car Audio & Video
Alesis M1 MKII bass ports
if desiring loud bass, keep port open. It is designed to be that way. If subs are in a corner, face the wall to change the wavelength and port noise wont be as evident.
Dec 23, 2008 | Alesis M1-Active MkII Main / Stereo...
Noise from speakers when playing basses
Offhand, could either be the subwoofer speaker itself or the electronics (amp and/or crossover). One way to determine is by physcially checking the sub speaker. When playing with bass on, pls try restricting speaker movement by pressing on it and see if the noise is reduced. Another is to temporarily replace the speaker. You can try speakers meant for the car, home entertainment or book shelf, just dont set the volume too high.
If the speakers are ruled out, then it would be the electronics inside. For this, you would need familiairty with electronic components and circuittry, a DVM and a soldering iron. Access to an oscilloscope and an audio signal generator would be nice but not a necessity. The idea is to inject a constant audio signal and determine where the noise (if electronic) is coming from. In most instances, it would be a leaky electrolytic capacitor either in the input stage or feedback loop. At other times, it would be also a capacitor in the band pass filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Audio Players & Recorders
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Car Audio & Video Logo
290 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
