How to remove front panel
SOURCE: dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they
refer to.
This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps.
This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps
You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps
This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps
You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep
This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep
You have a system memory problem
Five short beeps
You are facing a problem with your CPU
Long constant beeps
It’s a system memory problem
Short constant and high-pitched beeps
The temperature of your CPU is too high
SOURCE: I cant get my Dell Precision 690 to recognise a hard drive
Double check the bois to ensure you have all the Sata ports turned on. I have found in some Dell computers the only ports turned on are the ones in use when shipped from the factory.
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
SOURCE: when looking into setup, dell precision 690 not showing secondary processor
using my noggin i would say bios does not support the processor you are trying to use, and you will have to change the bios.
link below has useful info bios chip compatibility and so on.
http://www.tomshardware.com/forum/261984-28-upgrade-dell-precision
SOURCE: My Dell Precision Workstation 690 can not boot from the Disk
try this clean it whit a brush in the tracks never ower .clean the CD-WRITER/PLAYER with caned air.
Testimonial: "It worked!!"
