Question about Dual Electronics CECT P168 Cellular Phone
I have a cect i9+++ buzzing noise
I have a cect i9+++ so i think anyways but it has an ear piercing buzzing noise when others try to hear me wondering if anyone else has the problem or knows what to do about it thanks
This problem exists actually at all phones of this kind. The microphone replaced to a more sensitive type, but the firmware is not tuned for it. In this case, the electromagnetic field of the flash memory controller near the microphone generate this noise. If you pull out the mic from its case, the noise clams up immediately. This problem could be solved by a new firmware. The voulme of the microphone can not be adjusted through the phone's UI.
Posted on May 13, 2009
Hi bencebacsi,
I had this same problem with my daughters telephone i9+++. The microphone is seated in a little place in the metallic frame. I has a small hole for the sound. I made the hole a little bit bigger with a miniature metallic philips screw driver and seated the microphone again to its place. And voila....buzzing noise disappeared totally....at least for now....
Yours HarryHazard
Posted on May 29, 2009
  • HarryHazard May 29, 2009
    Hi guys again,
    I´ve been thinking why my method helped. I tried to solve bencebacsi´s problem by metallic earthed layer between microphone and the flash memory controller with no luck. There is propably an automated software to keep the sound level acceptable. If this hole in the metallic frame is too tight because of casting residuals, tries this software automaticly increase the sound level and at the same time it increases the noise. When You open this hole, there is enough signal for the phone to work without extra noise. This is quessing of course, but I had similar proglems with Nokia 9210i when microphone opening in the plastic cover was filled with dirt. I think that blakelock should try my method or return his phone to dealer. There are of course risks in shaping the metallic frame and You probaply would loose possible warranty, because You would have to open also the white paintsealed screw to get to the microphone.
    Yours HarryHazard
  • HarryHazard May 30, 2009
    Solution #3?
    Hi again guys. I been thinking again why this repair of mine fixed blakelockes and my daughter´s problem. The micropfone has a metallic surface and is seated to it´s place with a rubber piece to isolate it from the metallic frame. Could it be that this rubber was a little bit misplaced allowing the microphone to touch metallic frame? Metallic frame could act as an antenna and cause this buzzing noise. This would also explain why taking out the microphone from its original place could stop the extra noise. This could be easily tested but I do not want to put a working phone to pieces again.... :)
2 Suggested Answers
bradford_mor
  • 4 Answers
SOURCE: I have a cect i9+++ buzzing noise
Did anyone solve the "buzzing" noise that others hear when using a CECT phone? I see hints that you can adjust a parameter to solve, however, I can not find the specifics. Anyone know?
Posted on Oct 27, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
I have this i9 cect phone, others cannot hear what shoul I do?
Hi,when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
Take care.
Sep 14, 2010 | Dual Electronics CECT P168 Cellular Phone
Trying to set up internet and email on my I9 phone..
go to www.samsungmobile.co.uk . scroll down to where it says support then click on configure phone. click on wap or mms ( u will have to do both if you want both) then fill in details where it says phone model use samsung pixon ( u wont find cect i9 anyway) i did this and my works fine. hope this helps
Dec 06, 2009 | Dual Electronics CECT P168 Cellular Phone
HELP !!! How do i sync my cect i9
try going to this webpage,
http://www.mobilerated.com/cect-i9-home.html
please vote me! :)
Jul 27, 2009 | Lands Phones
Jun 02, 2009 | Dual Electronics CECT P168 Cellular Phone
Interference on opposite phone. Cect I9
I have this same problem - see hints it is about interference with the microphone. Using bluetooth avoids the problem - anyone know the fix??
Feb 26, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 phone
I have the same problem except that on mine you can't hear anything. I was just hearing a song and it suddenly stoped playing music. I check to see the i9 but it was still playin. I put on the ear buds and you could hear it, but the inner speaker wasnt working
i found some website where you can buy the speaker,.. here:
http://www.ipmart.com/main/product/Speaker,For,I9,Mobile,Phone,120011.php?prod=120011
I think i'mma buy one too.
Sep 12, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
2,654 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
