Question about Aquabot Turbo T
Aquabot Turbo T won't climb
My Aquabot Turbo T starts up okay. It moves along the floor and climbs walls. After a few minutes it seems to lose grip and gets stuck between floor and wall, spinning its treads. I'm guessing there's still suction because the bag does get dirty. It's just starting its third season. I thought the problem might be a result of picking up a couple small pool toys, but removing them and cleaning the bag didn't help. Any thoughts on what I should check or what might cause this?
  • SassyProf May 17, 2009
    We are having the same problem with our Aquabot... it barely has the energy to climb and after a few minutes can't seem to climb at all. What is wrong? What does it need? Does it need to go in for repair/refurbish?
  • Shell06 May 11, 2010
    If you have the unit out of the water for a while, the foam floats may be defective, absorbing water while in the pool and then losing weight due to absorbed water evaporating while out of the pool. Then, when the unit is put back in the pool, it will work well-for a short time. Then the floats water log again, giving the unit enough extra weight that it can't climb the wall and just stays on the wall, struggling. New floats and careful re-balancing will take care of the problem -until the replacement foam floats become permeable in a few years. S. Christian dansker01@msn.com
    Problem Solver:
  • 15 Answers
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
Posted on Aug 22, 2009
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
My aquabot has stopped cleaning the bottom of the pool. As soon as it gets to the walls of my 18x36 IG Pool it climbs the walls it won't go back down again. It just keeps going around the pool's walls...
i have run into this problem with a few units. as a hayward guy, i called support and was informed that there is too much flow through the unit. there are two physical adjustments. the top of the unit has a restrictor plate that simply screws into the top. after that, there is a secondary restriction plate available ... simply a washer that affixes onto the first restrictor plate. if the problem persists, dont clean filters as much so that there is restriction there.
Aug 23, 2013 | Aquabot Turbo T2 In - Ground Pool Cleaner
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot Turbo T2 flips over when it tries to climb walls. Water is not coming out the top but the unit is moving fine. Does it need a new pump motor or can something just be clogged inside??
the likely problem is the float/handle. Make sure it moves freely and is always in the straight up position when on the bottom of the pool. If it's not then it is the problem.
Jul 20, 2011 | Aquabot Turbo T
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Nov 08, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Our aquabot tips over and of course cannot run
Try the ideas given at the website: http://www.i-love-my-aquabot-automatic-pool-cleaner.com/
Shelby Christian dansker01@msn.com
Aug 04, 2009 | Aquabot In - Ground Robotic Pool Cleaner
My turbo bot does climb the walls of my pool. I have had it checked out with service. they could not find any problems. Any suggestions?
Not too uncommon. The float design is such that many units lack enough bouyancy to work well on wall climbing. New floats or added floats may help. S. Christian dansker01@msn.com
Jun 25, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Cleans only a bout 50% of my pool and doesnot clean walls. My pool shape is a foot print.
Both of these problems could be the installed floats. There are 3 of them normally installed, and they do have a finite service life. Old ones often absorb water, making the unit not cover the full pool area or climb walls, S. Christian dansker01@msn.com
Jun 15, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T Logo
1,032 people viewed this question
Top Aquabot Pool & Spa Experts
Ian Summerfield
Ian Summerfield
David Spradling
David Spradling
Robco Water
Robco Water
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
