Question about Sharp R-1610 Microwave Oven
Sharp 1611 My over the oven sharp 1611microwave will have the fan and click on for no reason at all. When you try to cook something and push cook, the fan and light come on but it does not cook. Other times it will run and then shut off completely. What do you suggest?
  • Sharp Master
  • 9,098 Answers
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
Posted on Oct 13, 2007
Sharp r580d
If the inside light, turntable and internal cooling fan all come on when you try to cook, but it's not heating, then check the bottom door switch and its mount.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Jan 08, 2014 | Sharp Microwave Ovens
The heat is inop - everything else works on my R-1754 Sharp. Any common problems?
If the fan and turntable are not working when you try to cook, it's likely a bad bottom door switch or mount. See this file.
If the fan and turntable ARE working when you try to cook, the problem is the primary interlock switch, the inverter, the magnetron, or a connection between one or more of them.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
We have the service manual at our site and have uploaded it here to help you.
You can order Sharp parts from Encompass here or call them toll-free at 866-779-5835.
Dec 14, 2010 | Sharp R-1754 Stainless Steel 1100 Watts...
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
How do I cook at 50%, what buttons do I push
Sharp Microwave,
Download a FREE manual -->click here<-- from Sharp
Please take the time to give this solution a fix ya rating.
clarkco
Mar 07, 2009 | Microwave Ovens
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
SHARP MICROWAVE R-1611 MADE VERY LOUD POP NOISE. NOW IT WON'T HEAT
20 A fuse inside m/w is out. The problem could be with HV condenser, one of the door switches shorted, computer board, magnetron. Needs technician to take a look on it.
Dec 03, 2008 | Sharp R-1480 Microwave Oven
Over the range Microwave trouble
It is a door switch problem of some sort.  I have two Sharp R-1611 units that do the same thing.  The light and fan come on, but not the heat, thank goodness.
I am going to replace it since the plastic for the case and door is cracked in numerous places.  I have spent several hours researching microwaves online have not a single clue what to replace the Sharp with.  Seems like every vendor has very good units and very bad units.  I guess you just pay your money and take your chances.
Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Hood light will not turn off
The problem is damage to the control circuit board. This damage happens usually when the lamps are removed or installed without disconnecting the oven from the power line first. We regularly repair these boards for this very problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by a search on Yahoo.com. It's important information to consider before proceeding.
Aug 29, 2006 | Sharp R-1610 Microwave Oven
Hood lights will not dim or turn off
The problem is damage to the control circuit board. This damage happens usually when the lamps are removed or installed without disconnecting the oven from the power line first. We regularly repair these boards for this very problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by a doing a search for "microwave safety.txt" on Yahoo.com. It's important information to consider before proceeding.
Aug 27, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1610 Microwave Oven Logo
109 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
