Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Blue transperant colour spread over the screen from the left.
It started on the left side of the picture (standing in front of the TV) with a transperant blueish colour. Now it is spread more over the whole picture at the bottom. The greens of the golf courses are not green any more as the grass is having a more blue colour like sometimes faces of white people. I have changed the projector lamp with no difference. Please advise what to do.
    Genius:
  • Sony Master
  • 1,148 Answers
IN THE MENU CHECK FOR A COLOR CONVERSION OPTION ,,USE IT ,,TO REALIGN THE COLORS
Posted on May 15, 2009
I have a sceptreflat screen hdtv that display a red picture Always
go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
Apr 22, 2017 | Televison & Video
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Picture is ugly we want to clean transperant sheet how can i open the transperant sheet?
I'm assuming you are asking about the Intermediate Transfer Belt. I remove the belt cleaning assy first just to get it out of may way. Open front door and remove the waste toner bottle. You will see a screw just up above and slightly to the left. Remove the screw and gently pull on the handle. It should come out easily. This is what is supposed to clean the belt assembly. Are you sure this isn't bad and is why you think you need to clean the belt? Set it aside for now. Open the right side access door and you should see the black belt. Remove the panel just above this by removing the one screw towards the front of the copier. Once removed you should a a blue handle. Lift up on this gently and it will lock in place. Then you should see the handles, front side one and rear side one, of the transfer belt assembly. Gently pull them straight out and the assembly should come out fairly easily. Be careful what you clean it with. Just use a clean, soft and dry cloth. Hope this helps.
Mar 26, 2011 | Canon imageRUNNER C3200 Copier
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Question
have convergence rebuilt........
Jun 01, 2008 | RCA HD52W56 52" Rear Projection HDTV
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Dec 19, 2007 | Samsung HP-S4253 Television
Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Oct 30, 2007 | Televison & Video
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
